Post by markrd250lc on Nov 29, 2023 19:58:32 GMT 1
Quick question(s), is an F2 sprocket carrier the same as a 350LC one , will the F2 fit and work in an LC wheel?
Thanks Mark
Post by dusty350 on Nov 29, 2023 20:38:18 GMT 1
Without having them to compare, I would say they are definitely not the same. Lc - 4 studs/nuts hold the 530 sprocket, with 4 cush dampers Pv - 6 bolts/nuts hold a 520 sprocket with 3 cush dampers. Wheel spacers will be different too as the Pv swingarm is much wider (approx 11mm iirc) at the wheel spindle end. Whether you can swap it all across ? - never tried it.
Dusty
Post by midlifecrisisrd on Nov 29, 2023 20:44:04 GMT 1
Deffo not as dusty says
Whole thing wouldn't swap either as LC wheel has 4 segments, ypvs only 3
Post by markrd250lc on Nov 29, 2023 20:54:10 GMT 1
Excellent thank you , i will keep looking for my 350 one , its somewhere in Sunbury so that narrows it down a bit
