Post by lostan7 on Nov 21, 2023 19:27:21 GMT 1
Evening all… Hope to be put in the right direction with my LCF 1WT PV. My engine came without flywheel or winding’s so thought a wait until one came along would be in order…! Unfortunately these seem to be a rarity… ( Or am I looking in the wrong places.? (Ebay/Breakers mostly) Already about to return a second one due to being off centre… 😤 Luckily I found a decent windings and ne pick-up. Next the flywheel. I’m finding available ones are usually missing the steel inners or are poorly riveted or put together. So I’m now looking for options to put in the bike…! Guidance from anyone who knows where I can find a decent one or if they can be bought off the shelf (As I don’t have one to exchange..😢)
Post by dusty350 on Nov 21, 2023 19:32:02 GMT 1
Post by lostan7 on Nov 21, 2023 20:28:02 GMT 1
Ooohh…! That looks like a nice bit of engineered kit. And Xmas is getting closer I guess…! Although that may require a number of different components I’m presuming… Uprated ignition/ coils etc…!! Thanks for the suggestion though…😎 Q. Can you run a rotor without the metal plate inners…? Or is it a job to have another welded in place..?
freddie19
Member is Online
Post by freddie19 on Nov 22, 2023 0:25:38 GMT 1
Hello mate, I've got a 1WT F2 flywheel. Bought it a couple of years back when I had trouble with my bike but I've never used it.
Not sure what they're worth, pm me if you're interested? 👍
dc12
Don’t get eliminated!
Post by dc12 on Nov 22, 2023 18:17:58 GMT 1
The VAPE system recommended above includes all of the components to replace the entire charging/ignition system. Plus you no longer have to deal with a 40 year old system.
Post by alankelly on Nov 26, 2023 22:01:41 GMT 1
Yes recommend a Vape system and fitted one on the yellow peril As other have said replaces all the 40 year + electrics and you get a much lighter flywheel too👍
Post by lostan7 on Nov 28, 2023 0:28:13 GMT 1
Thanks for the pics and advice/suggestions guys… Thankfully Gary (Freddie19) has sorted me out with a standard weighted rotor… 🤩 After seeing the massive weight difference I’ll be taking some serious crank considerations to my next engine build…🤔 👍🏼🤓
