Post by huggy76 on Nov 7, 2023 18:11:05 GMT 1
Does anyone know why the difference in the steering stems on the 2 yokes in the picture please. Powder coated one has a parallel stem and the original finish one has a narrower stem. Both have the same size forks and bearings? Is there an early and late one as I thought they where all the same? The lower bearing is loose on the powdered one, as think it was sandblasted, so hoping to use the other one. Thanks Andy
Post by midlifecrisisrd on Nov 7, 2023 20:29:33 GMT 1
Only thing springs to mind is that the later 350R had a different headstock on the frame and taper rollers as standard
Post by huggy76 on Nov 7, 2023 21:16:24 GMT 1
Thanks Steve
There are some numbers cast underneath if that helps anyone.
The powder coated one looks to have 92 and the standard finish one has Y0960?
Andy
