alig
Post by alig on Oct 29, 2023 15:58:39 GMT 1
Chaps I've a problem with indicators. Just aquired the bike, they don't work,no relay connected.so Borrowed one of a mates lc,still nothing.
However, when I've opened the headlight up, the lives coming from the indicators aren't connected to anything. I have 12v at the relay and block under the tank, but no power at rear indicators.all cable's connected as they should be as far as I can see.
now I'm stuck, I'm unsure of where to connect the lives in the headlight as no other wire receptor's are live, I've tried activating the switch while the multimeter is connected to anything that looks like it should take the bullet's but nothing.
Any advice would be much appreciated
alig
Post by alig on Oct 29, 2023 16:00:53 GMT 1
Post by LC_BOTT on Oct 29, 2023 17:52:52 GMT 1
The feeds to the front indies are show in your third pic, the brown and green single bullet connectors, you look to have connected both wires to the black negative double bullet connector.
After market indicators have black, and black/white tracer.
Originals are green/black, and brown/black for each side.
alig
Post by alig on Oct 29, 2023 18:07:58 GMT 1
Cheers I'll Go try. Thank you
alig
Post by alig on Oct 30, 2023 18:01:14 GMT 1
So. To no avail, I've tried everything i can, checked against the Haynes manual which doesn't actually say much. I have 12v at brown wire at relay. Nothing at the brn/wh at the bar switch Nothing at the brown or brn/wh at loom block near coil. Nothing inside the headlight on either feed. Nothing at rear feeds either. The loom is brand new. The bulb's work btw :-).
Any suggestions?
Everything else electrically works perfect
Post by midlifecrisisrd on Oct 30, 2023 18:43:46 GMT 1
Disconnect the self cancel and swap the spare wire over at the relay
alig
Post by alig on Oct 30, 2023 19:26:01 GMT 1
There isn't one on it Steve
alig
Post by alig on Oct 30, 2023 20:53:39 GMT 1
flic.kr/p/2pcPnGtThe brown wire in the 6 pin block shows 12v at the pin. (5 cable's) are in there.
alig
Post by alig on Oct 30, 2023 21:07:20 GMT 1
There isn't one on it Steve The spare is black ,on a bullet. I have a green wire with a bullet that goes into relay socket, the other 2 are fixed. I tried putting black onto green but nothing. Should I be connecting the black to one of the other one's?
Post by midlifecrisisrd on Oct 31, 2023 9:24:53 GMT 1
Yes, black into green then try a cheap 2 pin relay
Post by midlifecrisisrd on Oct 31, 2023 9:27:41 GMT 1
The genuine relays are very fussy
Had issues with my last LC build and my parts guy was telling me this
He ended up sending me 6 tested and working LC relays so I could try them all
Some wouldn't work, some flashed too fast and some too slow
Post by 4l04ever on Oct 31, 2023 9:33:35 GMT 1
The OEM flasher units may have the same issue as some other manufacturers where the capacitor inside is wearing out, so needs replacing. If anyone has a faulty flasher unit, it would be great to see a photo of inside to see if it can be repaired.
alig
Post by alig on Oct 31, 2023 14:32:14 GMT 1
Yes, black into green then try a cheap 2 pin relay Steve You absolute diamond.. WORKS.. top man, thank you so much
Post by cb250g5 on Oct 31, 2023 15:16:01 GMT 1
alig
Post by alig on Oct 31, 2023 20:58:28 GMT 1
That's the one i bought. Spot on
Post by JonW on Nov 1, 2023 3:36:51 GMT 1
The OEM flasher units may have the same issue as some other manufacturers where the capacitor inside is wearing out, so needs replacing. If anyone has a faulty flasher unit, it would be great to see a photo of inside to see if it can be repaired. Agreed Rob, these are not that hard to get into and replace parts IIRC. Some of the tops of the units of this age are pretty loose lol
