Post by tony2stroke on Oct 20, 2023 21:21:53 GMT 1
I have been reading the information about fitting said ignition system.
Question is! What spark plug caps are people using.
I ask as the instructions say 0-2kOhm.
When I ordered the vape from Norbo, I didn't give it a second thought, and bought the usual red NGK 5kOhm caps.
Interested to know what others are using, and if 2kOhm, where did you get them ?
I can find some 1kOhm ones would they be better than the 5kOhm ones ?
Thoughts welcome.
Post by tony2stroke on Oct 20, 2023 23:00:08 GMT 1
Found the answer to my question when I finished reading the information.
Don't go higher than 5k Ohm
But better to use 1 or 2k Ohm
Ordered some 1k Ohm ones
Post by badger1 on Oct 21, 2023 5:41:46 GMT 1
It usually comes with ht caps fitted, must admit they aren’t much cop. I changed mine to un resisted caps and plugs.
Post by lcmarky on Oct 21, 2023 9:49:36 GMT 1
I'm using the ones that come with it and they seem fine to me..
Post by badger1 on Oct 21, 2023 10:54:25 GMT 1
I'm using the ones that come with it and they seem fine to me.. I had the supplied vape ones on there for about 3500 miles then developed a miss fire Went to Change the leads and one of the caps fell to bits. So I gave them a go. Ngk screw in ones in my eyes are a lot better than the ones they supply
Post by beardy on Oct 21, 2023 12:59:43 GMT 1
When fitting mine a few years back and reading the blurb. I figured the caps that came with the system were probably non resistor type. So I bought 1k ohm caps to go with the non resistor plugs. Apart from the coil cdi failing on me it’s been fine like that 👍🏻
