mungo
Post by mungo on Oct 17, 2023 19:09:05 GMT 1
Bulbs are all ok,the left hand front won’t flash at all, the others all work ok but the left rear flashes quicker than both on the right any help appreciated
Post by shaunthe2nd on Oct 17, 2023 19:46:32 GMT 1
You say the bulbs are all ok, but are they all exactly the same voltage and wattage?
Post by midlifecrisisrd on Oct 17, 2023 20:14:03 GMT 1
Fromt left ain't working then 😎
Check you have the wires connected correctly in the headlight bucket
If front isn't connected then the rear will flash differently
Can't remember if dark brown or green is LH but check you don't have the indy connected to the light brown of the front brake switch
Check if there is a voltage and earth at the non functioning indy
mungo
Post by mungo on Oct 17, 2023 21:46:55 GMT 1
Sorry should have said all was working fine went out for a run out Saturday while out noticed front left wasn’t working put the bulb in other indicators and it worked ok
Post by midlifecrisisrd on Oct 17, 2023 21:49:35 GMT 1
Check if it's popped a bullet in the headlight bowl
Post by shaunthe2nd on Oct 17, 2023 23:14:39 GMT 1
Sounds like a poor connection, maybe earth. Also the connections inside the indicator crud up and create poor connections. Swap connections for L and R fronts green-brown over in headlight bowl to check if switches across.
mungo
Post by mungo on Oct 20, 2023 23:14:49 GMT 1
Thanks all sorted one of the bullet connections was loose
