Post by ferret79 on Mar 7, 2010 19:45:03 GMT 1
hi all, just thought i would share my streetfighter special with you its gonna be an ongoing project throughout this year, it will not all happen at once, as i need to keep bike partly on the road. i have a lot in store for this bike and today i started the long hard job in the shed of dread..lol yamaha tzr 125 upside down front end yamaha tzr 125 3 spoke wheel conversion mikuni 28mm flatslide carb jim lomas expansion pipe with stainless silencer wizards on nos nitrous kit 5-10 hp hopefully battery to be mounted under patrol tank to make space for nitrous solinoids, fuel pump and electrics and i have just brought these new bits from norbo, oils that i like to use not cheap but good quality 175 big bore kit looking a little sorry for its self at the moment but hopfully be a good addition to the bike and last picture for the moment the engine i will keep you up to date as i go, planty of work to be done next job is to make a alloy under tray, to replace exsiting original plastic one..
Post by Norbo on Mar 9, 2010 14:43:56 GMT 1
Bloody nice one . you dont see many trick lc125's spray jobs yes but with front and back end swops or a diferent seat i cant recall seeing many ever . Sounds like it will be a realy nice bike . I bet you get a lot looking at this ones as it progrses.
Post by ferret79 on Mar 10, 2010 18:19:53 GMT 1
thanks norbo, im having a lot of problems with the front usd front end, i cannot locate a top yoke and clip ons, from what i have found out, its a 45mm 4hw tzr125 front end , all the top yokes on ebay are for the 50mm 4dl import model, so im going to have to wait untill one becomes available somewhere. im not planning on fitting front end untill later this year, it will be a winter project, as i have to sort out taper roller bearings, shaft etc. i think im going to have to contact my local bearing dealer, and see what he can come up with, for my bearing measurments. the back end im planning on making my own swingarm, i have found a picture on the forum, cant remember if its this forum or not, but its an alloy tube arm, and im planning on making the same kind, but using steel tubing, this way its cheaper on materials and welding as i can weld it myself. i will upload a pic of the arm im going to copy the design of, anyway here are some more pics of the shock mount and battery box mostly there, shock mount jack up kit has moved the shock 40mm, which will give me a much higher back end, for the look i want. swingarm design i want to copy using steel tubing top shock mount jack up fabrication battery box now located in top frame rails heres some pictures of my barrel & head over haul. and my homemade 8mm reed spacer, which has since been polished to remove rough file marks, will probably nned to make another soon to accomadate nitrous oxide fogger thread cylinder head has since been blacked with pj1 black more to follow as i get time and progress further
Post by twostroker on Mar 10, 2010 18:54:23 GMT 1
whats the braided pipe going in to the gearbox oil filler cap for ?
Post by ferret79 on Mar 10, 2010 19:26:24 GMT 1
it was a breather that went to a tank that i put on a while ago, it will be coming of and having a pro bolt annodized filler cap.
Post by Norbo on Mar 11, 2010 9:16:40 GMT 1
Firts i hope your not going to fit that (cheep crap thai piston) i can see in one of the picks . Front end. A simple spacer will sorght out the bearings yopu need SSY 125 and you wont be able to get them from a bearing place sorry . Spondon 440 makes yokes and they are the very best quolity many clip ons will fit and if they are a little to small you can just have them bored out . . Fogger in to the reed spacer is a good idea. dont forget you will now need a twin out let tap or a 8mm single with a spliter on as you need a second feed for the nos fuel as well as the normal running fuel. That alloy swing arm was made by NK racing .
Post by ferret79 on Mar 11, 2010 19:35:58 GMT 1
thanks for the help and advice norbo. could you possibly give me a bit more information on this ssy 125 spacer, is it a bearing set or just a spacer? if possible could you give me a link to what im looking for exactly? the nitrous fitting and fuel supply is already thought out, i have some some experience of fitting nitrous to bikes, and im grtting a lot of help from my friend who has done it many times, thanks for any help you or anyone else can give me.
Post by jasper2608 on May 8, 2010 15:44:50 GMT 1
need more pics want to see how you got on
cubz
Post by cubz on Dec 25, 2010 22:09:35 GMT 1
Are you doing anything to strengthen the bottom end/crank? will it take all the new power? i have been thinking about doing something similar with my bike but i dont want to be rebuilding it every month. have you got any more pics
Post by tsa on Dec 30, 2010 12:45:07 GMT 1
Ive got a RG125F frontend for my RD170LC and a nice Metmachex Alloy Swingarm shouldbe fitted next year some time. But yours is looking good mate
Post by simon998 on Dec 30, 2010 13:04:24 GMT 1
That swing arm is a work of art. I'll be watching this!
Post by billy on Jan 2, 2011 4:38:49 GMT 1
Hey ferret79, why have you placed the reed spacer behind the reed valve? I thought the only reason you used them was to space the reed valve further out in order to get better flow up the boost port..
Post by tsa on Jan 2, 2011 13:29:42 GMT 1
I would recommend getting the crank done and take it to PJ engineering in Birmingham. Have the rod and bigend changed for a YZ125 with the same rod length. The Big end is 1mm wider and has a silver coated bearing. Mines been in my tuned 170 for 6 years now and had lots of abuse too. I also fitted a whole clutch from the DTR125 as it has more springs and plates.
Post by simon998 on Feb 2, 2018 11:29:33 GMT 1
What ever happened to this?
Post by dusty350 on Feb 2, 2018 16:52:37 GMT 1
Ferret hasn't been on this forum since September 2013 unfortunately The link to his website is dead too. Dusty
Post by simon998 on Feb 3, 2018 8:12:20 GMT 1
Hope he's alright. I had a look at his other posts and it seems he did indeed finish this, not completely but it was together and running.
Post by dusty350 on Feb 3, 2018 9:42:47 GMT 1
A lot of guys come and go, for a variety of different reasons I would think. If you look through the members list, there are lots that were here but not anymore. Nice to see that thread though. I wouldn't mind doing a 125 special at some point Dusty
Post by simon998 on Jun 26, 2022 10:46:49 GMT 1
In a weird sequence of events, I'm running the big bore kit from earlier this thread on my bike now.
Post by Norbo on Jun 29, 2022 8:34:44 GMT 1
shame all the pics have gone on this thread
Post by Gunny on Jul 10, 2022 15:47:06 GMT 1
I can see them all ?
