Post by nomoreheros on Oct 5, 2023 11:40:02 GMT 1
Anyone have any cleaning tips for the plastic water tanks TIA
Post by shaunthe2nd on Oct 5, 2023 12:15:42 GMT 1
Household products and a long thin flexi brush.
red998
Post by red998 on Oct 5, 2023 13:12:43 GMT 1
If you have an ultrasonic cleaner it seems that will work with the correct cleaning solution. I have had some amazing results after purchasing one, it's a good investment, that, for me, has paid dividends.
Post by bezzer on Oct 5, 2023 14:08:35 GMT 1
Just watched a video on this very subject, and best results seemed to be bleach, washing up liquid and boiling water?, the chap also used, bicarbonate of soda, white vinegar and dishwasher tablets with little or no effect. I should add his exp tank was quite heavily rust stained internally.
Post by dougw on Oct 5, 2023 14:12:19 GMT 1
As above, and I cut the head off a toothbrush and fastened it onto the end of a bit of coat hanger wire.
Top bodge.
Post by peter1962 on Oct 5, 2023 14:30:03 GMT 1
Try a babys bottle cleaner, with gunk, then clean that out with hot soapy water, the gunk should help with any oily stains
Post by lcmarky on Oct 5, 2023 15:11:48 GMT 1
Pressure washer up it's chuff!
Post by tony2stroke on Oct 5, 2023 16:01:44 GMT 1
The cleaning solution I find best is biological washing powder with hot water, it's a degreaser, most have bleach in there too, it's slightly abrasive, washes off with cold water without leaving anything behind.
This is only biological washing powder. not liquid tabs or any other type.
I use it for most cleaning duties with a small dustpan brush. Works well.
Post by midlifecrisisrd on Oct 5, 2023 18:48:48 GMT 1
Don't use boiling water and bleach
The chlorine flashes off around 60 degrees
Post by tony2stroke on Oct 5, 2023 19:24:17 GMT 1
Don't use boiling water and bleach The chlorine flashes off around 60 degrees Steve What ?
Post by midlifecrisisrd on Oct 5, 2023 20:49:43 GMT 1
Don't use boiling water and bleach The chlorine flashes off around 60 degrees Steve What ? Chlorine bleach degrades at temperature Boiling water with bleach in it will remove the chlorine Steve
Post by tony2stroke on Oct 5, 2023 21:42:37 GMT 1
Chlorine bleach degrades at temperature Boiling water with bleach in it will remove the chlorine Steve Ah right, so the bleach is chlorine and boiling it removes the bleaching properties. Is that right.
Post by arrow on Oct 5, 2023 22:11:12 GMT 1
About ⅓ full with washing powder solution, couple of teaspoons of uncooked basmati rice. Shake well. Rince well. Job done.
Post by midlifecrisisrd on Oct 5, 2023 22:24:59 GMT 1
Chlorine bleach degrades at temperature Boiling water with bleach in it will remove the chlorine Steve Ah right, so the bleach is chlorine and boiling it removes the bleaching properties. Is that right. Yes Chlorine will evaporate out of water at room temperature Steve
Post by linx on Oct 6, 2023 10:59:34 GMT 1
I just put mine in the dishwasher, which did a good job. Your bracket is already rusty. So it's not going to make that any worse.
