Post by philthat on Sept 30, 2023 21:42:44 GMT 1
Hello, Does anyone have a suggestion for cleaning power valves with carbon on them, without damaging them? Many thanks.
Post by dusty350 on Oct 1, 2023 10:24:25 GMT 1
I use a small brass brush - usually come in a pack with a steel and a nylon brush - usually found in Pound shops or the like. It wont damage the steel Pv and gets the carbon off a treat
Post by jon on Oct 1, 2023 10:45:30 GMT 1
I use a small brass brush - usually come in a pack with a steel and a nylon brush - usually found in Pound shops or the like. It wont damage the steel Pv and gets the carbon off a treat Steel powervalves? Surely you mean aluminium? I left a set in a sealed jar with petrol for a couple of years and it removed all carbon. Hadn’t intended to but just forgot about them. Jon
Post by linx on Oct 2, 2023 6:41:51 GMT 1
Hello, Does anyone have a suggestion for cleaning power valves with carbon on them, without damaging them? Many thanks. I use steel wool. Seems to work well without damage.
red998
Post by red998 on Oct 2, 2023 8:24:37 GMT 1
Ultrasonic cleaning might work depending how hard the carbon deposit is, maybe combine it with a carb. cleaner solution.
Post by headcoats on Oct 2, 2023 9:41:00 GMT 1
Oven cleaner but Don't leave on too long Haven't tried it for this but used it to remove anodising
Post by JonW on Oct 2, 2023 9:45:22 GMT 1
yep people did used to suggest oven cleaner... someone once told me he used a wire wheel... Ive always used a gentle scraper and brass brushes with WD40.
Post by stusco on Oct 2, 2023 15:56:43 GMT 1
Ultrasonic cleaning might work depending how hard the carbon deposit is, maybe combine it with a carb. cleaner solution. If you have the water hot all the bushes fall apart due to different metal expansion
Post by freddie19 on Oct 2, 2023 18:05:36 GMT 1
Wire brush and Solvol Autosol definitely the way to go and..........a lot of elbow grease! 😁 This is the powervalve from my LC2, before and after cleaning. 👍
Post by philthat on Oct 2, 2023 21:01:28 GMT 1
Ok, great thanks. I've got an ultrasound cleaner. I'll give that a go first. Then move onto the brush and Solvo treatment.
Post by bezzer on Oct 2, 2023 23:25:10 GMT 1
We’d have soaked them in a jam jar full of petrol overnight back in our youth surely? 😁
Post by stirling11 on Oct 4, 2023 14:59:00 GMT 1
Use a non caustic paint stripper, ie the ingredient should be methylene chloride then buff off with a brass wire wheel
It won't affect the aluminium, caustic, or oven cleaner will
Post by jon on Oct 4, 2023 18:20:47 GMT 1
We’d have soaked them in a jam jar full of petrol overnight back in our youth surely? 😁 +1 as I said. Jon
Post by philthat on Oct 4, 2023 22:06:04 GMT 1
Well, I Soaked them overnight in white spirit to remove some of the gunk. Then I gave it a go with the ultrasonic cleaner, with some result. I have some modern paint stripper at work. So I'll give that a go as well. before getting the solvo and Brass wire brushes on them.
Post by stirling11 on Oct 5, 2023 12:50:11 GMT 1
Make sure that paint stripper DOES NOT mention the following ingredients
Sodium Hydroxide Caustic Soda Strong Alkali
If it does, do not use it or you will lose your PV's
Post by steve63 on Oct 5, 2023 13:04:08 GMT 1
I've often wondered if there is a chemical that removes carbon but doesn't touch aluminium. It would make for a totally labour free method of cleaning anything aluminium caked in carbon. So far I've not found anything. I've left a set of RGV power valves soaking in carb cleaner in a sealed jar for weeks. Virtually un effected, i.e. not cleaned. I can't recall If I've actually tried the ultrasonic cleaner or not. Now I have my all new one it could be time to try. One thing I would say is that anything harder than aluminium will inevitably scratch it. So anything like wire wool, steel wire brush or even a brass wire brush. Depends how hard you press how much though. Some 'brass' wire brushes are just brass coated and still steel underneath. Even if it says brass I would still check. Coating steel with brass is much cheaper than making them out of brass
Post by midlifecrisisrd on Oct 6, 2023 18:14:31 GMT 1
Acetone
Steve 😁
Post by steeley on Oct 7, 2023 5:22:01 GMT 1
Once i have got the crud off the valves i give them a polish up with the buffing mops and polish .
Post by stirling11 on Oct 7, 2023 14:00:56 GMT 1
Methylene Chloride will remove carbon and won't touch aluminium
Post by wonkywheel on Oct 7, 2023 20:39:06 GMT 1
Sounds like we all have different approaches. I used a kitchen scouring pad with Autosol and WD40 then buffed with a cloth. The flexibility of the pad worked well. Not highly polished, but good enough for me.
Post by urbantangleweed on Oct 9, 2023 7:53:16 GMT 1
+1 for soaking in petrol for a day or two, an old fashioned suede brush works well after that bit.
