Post by doohanno1 on Sept 19, 2023 13:57:43 GMT 1
After doing a search i'm still confused.com... Do YSS238 fork emulators fit lc350 fork legs.. I'd like to try this mod over the winter.. Tks.
Post by derek500 on Sept 19, 2023 16:22:14 GMT 1
I fitted 238s to my RD400 forks they were isted for honda CB550!
Post by doohanno1 on Sept 20, 2023 11:36:25 GMT 1
I think the 400 forks are bigger so still wondering if anyone can shed some light on this.. Tjs.
Post by veg on Sept 20, 2023 12:07:23 GMT 1
Do a search on Yss or emulator in the search term there are loads of answers. 👍
Post by derek500 on Sept 20, 2023 14:17:58 GMT 1
I measured the fork slider internal diameter and compared to YSS list, 238 is the diameter of the emulator
Post by doohanno1 on Sept 20, 2023 16:15:02 GMT 1
I'm not in a position at the moment to look so would anybody know the internal diameter of the lc leg .? Tks.
Post by elsiefan on Sept 20, 2023 16:36:36 GMT 1
I did look into this last winter when rebuilding my LC. I believe they do not fit as standard, but some modification is required, though exactly what, wasn't completely clear. Due to this I didn't fit them to mine in the end.
Post by derek500 on Sept 20, 2023 17:54:09 GMT 1
You need to enlarge the hole(s) in the damper rod, 2 min job
Post by jon on Sept 20, 2023 22:26:43 GMT 1
You need to enlarge the hole(s) in the damper rod, 2 min job From memory as well as enlarging the existing holes, you need to drill some more. you need to make sure you deburr them too. Much more than 2 minutes, but a simple job. Jon
Post by doohanno1 on Sept 21, 2023 13:31:12 GMT 1
You need to enlarge the hole(s) in the damper rod, 2 min job From memory as well as enlarging the existing holes, you need to drill some more. you need to make sure you deburr them too. Much more than 2 minutes, but a simple job. Jon This part of the process i understand..The question is, do the emulators drop into the fork leg or is there some machining required for the lc leg. Tks.
Post by wallcraft on Sept 21, 2023 13:59:22 GMT 1
100% the 238 is the correct kit for the 4LO, no machining to do they drop straight into the damper rods.👍
Mark.
Post by doohanno1 on Sept 21, 2023 15:27:53 GMT 1
100% the 238 is the correct kit for the 4LO, no machining to do they drop straight into the damper rods.👍 Mark. Thats great, Thanks very much..
Post by derek500 on Sept 21, 2023 19:18:50 GMT 1
Post by derek500 on Sept 21, 2023 19:19:56 GMT 1
From memory it was a 2 minute job, that's including reading the instructions 😀
Post by jon on Sept 21, 2023 20:18:22 GMT 1
From memory it was a 2 minute job, that's including reading the instructions 😀 Probably like a lot of us here at a similar age, our memories are not always accurate? LOL Jon
Post by elsiefan on Sept 22, 2023 15:04:36 GMT 1
I thought the late Queen put it best "Recollections may vary"
Post by doohanno1 on Sept 22, 2023 19:23:01 GMT 1
So moving on... If one replaces the old springs with same dimension new ones,should these be reduced in lenght to compensate for the " height" of the emulator.. Tks..
Post by derek500 on Sept 22, 2023 19:52:35 GMT 1
So tell him Jon, or shall I?
Post by doohanno1 on Sept 22, 2023 20:27:36 GMT 1
Ah go on...
Post by derek500 on Sept 23, 2023 11:26:24 GMT 1
Spring remains the same length, cut the top spacer down to suit, 20mm I seem to remember is the Emulator height.(I'm sure Jon will tell us)
Post by doohanno1 on Sept 23, 2023 18:12:16 GMT 1
Spring remains the same length, cut the top spacer down to suit, 20mm I seem to remember is the Emulator height.(I'm sure Jon will tell us) Surely there is no top spacer in a lc fork.!!
Post by derek500 on Sept 23, 2023 19:06:22 GMT 1
Ah so no spacer means either cut down the springs, or can you modify top threaded caps? OR wonder what it would be like with extra preload?
Post by elsiefan on Sept 23, 2023 23:34:48 GMT 1
This was why I didn't fit them to mine in the end! "I believe they do not fit as standard, but some modification is required, though exactly what, wasn't completely clear."
Post by dougw on Sept 28, 2023 9:37:27 GMT 1
I fitted the YSS238 emulators to my 4L0 forks two years ago.
Drilled the damper rods as per instructions , cut 10mm of the tight wound end of spring and ground end flat. (Emulators add 15mm of preload).
ATF oil .
Emulators working well , done a few thousand miles , solo, two up and a weekend doing Curborough Twisty Sprint on it .
