Post by LC_BOTT on Sept 6, 2023 12:05:54 GMT 1
Looking for some 10mm ID fuel pipe, removed a section from a tap this weekend, and it just snapped off the barb, the rest is too short to stretch it. Don't want that awful braided re-enforced stuff.
Any recommendations please, can't seem to find much around, Carrot Cycles used to do loads.
Post by Chewie01 on Sept 6, 2023 12:20:39 GMT 1
Post by Chewie01 on Sept 6, 2023 12:23:09 GMT 1
Post by LC_BOTT on Sept 6, 2023 18:48:27 GMT 1
Thanks, but neither of those are 10mm ID, this is the problem I'm finding.
Post by arrow on Sept 6, 2023 18:53:57 GMT 1
10mm ID? What's the application?
Post by LC_BOTT on Sept 6, 2023 20:18:20 GMT 1
RD500 tank to tap pipes. I think 3MA ones are the same size as well?
Post by midlifecrisisrd on Sept 6, 2023 20:55:05 GMT 1
Fuel pipe
Sept 6, 2023 21:27:38 GMT 1
via mobile
Post by veg on Sept 6, 2023 21:27:38 GMT 1
Doesn’t Norbo stock it then? I got my 8mm for my tz tap from him.
Post by muttsnuts on Sept 7, 2023 21:41:10 GMT 1
I have some 10mm fuel pipe, but its very thick walled, its a snug fit on the 500's, got to make sure you route it right otherwise it gets kinked and restricts the flow
Post by jon on Sept 7, 2023 22:54:41 GMT 1
I always use Tyson hose. Being yellow, maybe not so good for a standard build, but fine for a hybrid.
Post by JonW on Sept 8, 2023 7:38:50 GMT 1
I believe you can still buy the OEM hoses? Depends on the style of build as Jon says of course.
Post by LC_BOTT on Sept 8, 2023 7:40:49 GMT 1
Thanks all, going to try the stuff Steve's linked to, got some thick walled pipe from a car, but it's far too stiff to route smoothly. I have used Tygon before on a hybrid, but I didn't think they made it in the bigger sizes? Although it's very pricey. it's possibly worth it.
Yes Jon, still avaulable but nearly £40 for each pipe
Post by JonW on Sept 9, 2023 2:45:46 GMT 1
Thanks all, going to try the stuff Steve's linked to, got some thick walled pipe from a car, but it's far too stiff to route smoothly. I have used Tygon before on a hybrid, but I didn't think they made it in the bigger sizes? Although it's very pricey. it's possibly worth it. Yes Jon, still avaulable but nearly £40 for each pipe Hmm, thats the crazy local yam pricing i guess, its cheaper elsewhere of course. The OEM is at least correctly curved which helps... {justification made... thin but... lol}
Post by LC_BOTT on Oct 30, 2023 13:52:12 GMT 1
