Post by element137 on Sept 6, 2023 10:59:32 GMT 1
Does anyone know if seat base/seat from LC's or PV's are the same and interchangeable please ?- reason I ask - is I have accumulated two seats for the LC2 resto project I am doing - one sits very high at the back ( if you were looking from the number plate, directly behind the bike ) and the very back edge leaves about a 1.0cm gap when fully latched into the frame catches - the other one I have sits more flush, so a much tighter gap when you look from the back, however - I noticed that some of the plastic moulding has been cut away underneath, so wondered if that's what making it sit better - or are there different versions of the base and hence different fitting/flush at the back ? - from memory , both the bases are marked up 29L plus the dating marks moulded in.
Post by shaunthe2nd on Sept 6, 2023 11:54:58 GMT 1
Seat base for 4L0 and 31k are diferent.
Post by midlifecrisisrd on Sept 7, 2023 7:36:03 GMT 1
29L is the correct seat base
Post by element137 on Sept 7, 2023 9:41:17 GMT 1
Thanks both, the two seats I have are both 29L but seem to fit very differently, its why I thought there was different variants of 29L - I am going to retrim one of them ( have the facilities at work to get it done ) but with the bases - one base fits better( but its been butchered ) and the other one - the base all in tact - but horrible gapping at the rear - strange one .
