Post by hopper350 on Sept 3, 2023 22:00:12 GMT 1
Hi, I need a clear clutch window / o-ring as mines cracked, does anyone know a supplier please, cheers Paul
Post by rigga on Sept 3, 2023 22:18:53 GMT 1
Measure it, should be able to pick one up on eBay
Post by 4l04ever on Sept 4, 2023 1:05:03 GMT 1
Post by huggy76 on Sept 20, 2023 10:41:30 GMT 1
If you measure the diameter of your original o ring you can then buy o ring cord on eBay and make your own
Post by chrisg on Sept 25, 2023 20:50:27 GMT 1
Simply bearings will have one, check the size.
Post by jon on Sept 25, 2023 22:31:29 GMT 1
Maybe I’m misreading the OP, but when he says cracked, is he on about the window itself rather than the o ring?
I must make some more of these at some time as once you go down this root you need to be able to get replacements if yours cracks.
Post by JonW on Sept 26, 2023 0:36:00 GMT 1
Any bearing shop should stock o rings of all sizes, plus even if not perfect you can stretch an o ring slightly, but there is a technique.
Anyway, take old one to counter and see what the bloke says he can do for you...
