stuard
Enter your message here...
Post by stuard on Aug 31, 2023 16:18:53 GMT 1
Hi all. My 1974 RD350A has used about 2 lites of synthetic 2 stroke oil in around 400 miles. Does this seem about right? TiA Stuart
Post by midlifecrisisrd on Aug 31, 2023 18:12:44 GMT 1
What kind of mpg are you getting?
Post by veg on Aug 31, 2023 20:43:48 GMT 1
My 350lc is about 180 miles pr litre it’s running big carbs and the oil pumps has been altered to reflect it.
Post by reedpete on Aug 31, 2023 21:03:00 GMT 1
400 miles … 40mpg? say 10 gallons … 45 litres… 2 litres of oil would be 22.5:1 I doubt the mpg is much worse than that so the fuel oil ration seems too low…
Post by midlifecrisisrd on Sept 1, 2023 8:46:23 GMT 1
400 miles … 40mpg? say 10 gallons … 45 litres… 2 litres of oil would be 22.5:1 I doubt the mpg is much worse than that so the fuel oil ration seems too low… That's why I asked about mpg I'd done a similar mental calculation and got it between 20 and 25:1 Unless he's on full throttle from start up to switch off 🤣 Steve
Post by reedpete on Sept 1, 2023 9:31:01 GMT 1
400 miles … 40mpg? say 10 gallons … 45 litres… 2 litres of oil would be 22.5:1 I doubt the mpg is much worse than that so the fuel oil ration seems too low… That's why I asked about mpg I'd done a similar mental calculation and got it between 20 and 25:1 Unless he's on full throttle from start up to switch off 🤣 Steve You hoped he knew…. I assumed he didn’t know but still wanted and answer… 😂 Either way… sounds like a bit too much oil… but nothing more than cable wrongly adjusted or something…
Post by arrow on Sept 1, 2023 10:02:03 GMT 1
Send two photos showing the pulley position. One at full bore and one at closed throttle. Also, please state the minimum stroke setting.
