Post by tacky1 on Aug 29, 2023 4:12:27 GMT 1
Ive been searching and not found much info, I'm fitting an R6 front end, what do you use for a speedo, I have some LC clocks and YPVS clocks and I think a few other sets, TZR/RD500 etc, Is there some way to retrofit a speedo in there to run from a magnet off the front disc... Trying to figure out what to run in the original clocks, I dont really want a Koso setup.....
Post by JonW on Aug 29, 2023 5:50:14 GMT 1
what bike?
Asking as LC has mechanical tacho drive... later RZs not etc but they do have leccy.
Post by midlifecrisisrd on Aug 29, 2023 8:43:21 GMT 1
If you are wanting to keep LC clock cases then Koso instruments in LC cases is about your only option
Al does printed instrument cases to convert
Either that or you are looking at grafting in a GPS speedo with a digital read out
red998
Post by red998 on Aug 29, 2023 9:19:54 GMT 1
You might be able to use a Translogic dashboard but you would probably only be able to display minimal information. The photos are of one fitted to a Ducati 748/998. Speedo pickup is via the rear disc in this case but can be setup on the front. On these models the speedo is driven by cable and the rev counter and temp. gauge are electric. You can download fitting instructions from the internet to see if it will work for you. 3 by
2 by
1 by
Speedo sensor translogic by
Post by veg on Aug 29, 2023 12:23:59 GMT 1
Is the R6 a mechanical drive or a later electronic one? Could you not use R6 clocks to make it easier? My thoughts on fitting electronic to a Lc are one thing also to be mindful of is over or under reading. Whilst mine has been set up (koso) to run of the disc I thought it was bang on, however at 30mph shown I’m doing nearly 40 and it gets progressively inaccurate at approx 60 shown I’m doing 80 etc this was compared to my mates 765 rs. This won’t be an issue if you keep a mechanical drive from an equivalent yamaha from the same period to the clocks. The other consideration is buying electronic clocks they will need to be set up and wired properly.
Post by tacky1 on Aug 30, 2023 2:27:01 GMT 1
Thanks Guys, some options there. I should have been clearer, Im rebuilding an RZ350 with an early R6 front end, I have a bunch of clock sets and its going to be a hybrid and I dont mind which set I use, Good info on Al though, Ill get in touch with him and see what he has to offer,,,,
Post by tacky1 on Aug 30, 2023 2:29:19 GMT 1
Is the R6 a mechanical drive or a later electronic one? Could you not use R6 clocks to make it easier? My thoughts on fitting electronic to a Lc are one thing also to be mindful of is over or under reading. Whilst mine has been set up (koso) to run of the disc I thought it was bang on, however at 30mph shown I’m doing nearly 40 and it gets progressively inaccurate at approx 60 shown I’m doing 80 etc this was compared to my mates 765 rs. This won’t be an issue if you keep a mechanical drive from an equivalent yamaha from the same period to the clocks. The other consideration is buying electronic clocks they will need to be set up and wired properly. The R6 is all digi.. Speedo is driver from a gearbox sensor unfortunately...
I might go the Koso route though...
Post by JonW on Aug 30, 2023 2:36:23 GMT 1
Very early R6 can poss be used, its like the R1 (which was easier to make work, tho not 5mins) from a decade back when they were cheap. the rzrd500 350 forum has a long thread on that info. FWIW Speedo healer and tacho feed fudger (tech term) can fix the inputs. depends on how much effort you want to put in... I have an R1 setup i should use or sell really, problem is these things used to be cheap but not anymore since early R1s are worth $$$ now, but stuff always cheaper in US for you
Post by tacky1 on Aug 31, 2023 0:07:22 GMT 1
Very early R6 can poss be used, its like the R1 (which was easier to make work, tho not 5mins) from a decade back when they were cheap. the rzrd500 350 forum has a long thread on that info. FWIW Speedo healer and tacho feed fudger (tech term) can fix the inputs. depends on how much effort you want to put in... I have an R1 setup i should use or sell really, problem is these things used to be cheap but not anymore since early R1s are worth $$$ now, but stuff always cheaper in US for you Nice one Jon, thanks. I didn't know I could make the R1/6 speedo work, I think I have a few of them here in a box somewhere, Just need to look for the info on making them work
Post by midlifecrisisrd on Aug 31, 2023 7:24:07 GMT 1
I remember nikfubar doing it
Speedo healer then the little box for Yamagammas to convert 2 pulses per rev to 1
Post by tacky1 on Sept 2, 2023 16:09:39 GMT 1
I remember nikfubar doing it Speedo healer then the little box for Yamagammas to convert 2 pulses per rev to 1 Steve Thanks Steve. I’ll check that out 👍
Post by tacky1 on Sept 6, 2023 21:32:16 GMT 1
Quick update. I bought the pods from Alan and I have a set of LC clocks with no innards. I bought the Koso clocks to fit in there. I’ll update when I have them finished
