Post by veg on Aug 28, 2023 11:01:27 GMT 1
Looking at an upgrade, a billet lock up clutch do any come with oil pump facility or do they all have to be pre mix? All Norbo seem to lose the oil pump.
Post by arrow on Aug 28, 2023 11:04:21 GMT 1
Hi Veg, how does it lose the oil pump facility, Different side case??
Post by veg on Aug 28, 2023 11:26:22 GMT 1
Hi Gary Yes looking at the billet cover there isn’t the facility to run the pump I’ve had a message from Johnny about it. I’m not sure if Dave’s are different.
Post by 4l04ever on Aug 28, 2023 11:30:03 GMT 1
You can get some that use a modified standard cover which gets an extension welded on.
Post by veg on Aug 28, 2023 13:28:27 GMT 1
Thanks Rob. Just wondered if anyone did one with the oil pump I’ll speak to Dave see what his are like. I don’t want to lose the oil pump especially as it’s been set up properly by Gary.
Post by midlifecrisisrd on Aug 28, 2023 13:40:37 GMT 1
If its practicality over looks then a stealth lock up goes under a standard case
Post by veg on Aug 28, 2023 13:45:46 GMT 1
I do need a lock up/heavy duty clutch and I fancied a billet cover. I could do the clear cover conversion I guess.
Post by Tobyjugs on Aug 28, 2023 14:58:26 GMT 1
I do need a lock up/heavy duty clutch and I fancied a billet cover. I could do the clear cover conversion I guess. I've never seen a race bike with a washing machine window. DON'T DO IT Get an 8 plate set up. Or better still you know what it needs.
Post by veg on Aug 28, 2023 15:16:13 GMT 1
Tony I know I can’t justify/afford it. Johnny said I need to talk to you about it 😁. I’m open to the change and I need to think of the bling factor as well. Plus I was thinking of weight again 😁. Unless of course you know of one?
Post by dusty350 on Aug 28, 2023 16:17:10 GMT 1
I had one like Norbo sells. Came with a bike project and spares. I did toy with fitting it - it was the Cafe racer/Tz Pv engine build; 20190303_165809 by dusty miller, on Flickr Certainly bling, but I didn't need a lock up but I did need the oil pump, so I sold it on. It may be possible, with some careful measuring and machining work, to retro fit a pump, but It would look crap I think and would rack up more £££ on top of the case cost.
Post by veg on Aug 28, 2023 16:34:17 GMT 1
That’s my thought Dusty. I do not want to go pre mix, whilst it may be possible to fit one to Norbo’s it’s more hassle that I don’t need.
Post by jessy03 on Aug 28, 2023 17:23:17 GMT 1
Post by veg on Aug 28, 2023 18:09:56 GMT 1
Perfect. 👍
Post by JonW on Aug 29, 2023 0:24:28 GMT 1
the bolt/weld on kits were the way to go for this look i reckon, the full side cover is a banshee item hence the lack of oil pump.
Agreed window isnt racey, its bling but its amusing to own. no worse than so many other things we fit lol
Post by Tobyjugs on Aug 30, 2023 15:03:39 GMT 1
Tim i did fit a stealth lock up clutch to a 4L0 engine and it worked very well for the sprint competition it was in. It was easily used for another 6 months after that on the road.
You would need to fit an YPVS clutch side casing and you can get away with light springs.
It still becomes heavy on the hand but that will be after a long period driving the bike constantly.
Post by rigga on Aug 30, 2023 15:09:39 GMT 1
I only run 4 springs in mine, the lock up prevents slippage so get a lighter clutch action than if I run all 6.
If I had a more powerful engine I'd prob have to fit all of them.
Post by veg on Aug 30, 2023 16:25:57 GMT 1
I’m loving Darren’s response and although it’s a banshee fitting I assume they fit a std Lc motor.
Post by rigga on Aug 30, 2023 19:37:05 GMT 1
I’m loving Darren’s response and although it’s a banshee fitting I assume they fit a std Lc motor. Yes they fit LC, had this off Norbo years ago, but no longer available. Welded extension onto PV cover.
