Post by veg on Aug 28, 2023 10:57:29 GMT 1
Can’t remember but does a Ypvs left engine cover fit an Lc?
Post by foxyjohn on Aug 28, 2023 11:29:10 GMT 1
Yes it will fit Veg but you will have to trim it to clear the frame
Post by Yogi on Aug 28, 2023 11:31:33 GMT 1
As foxy said you need to trim the right side to match the Lc frame It’s not a lot 👍
Post by 4l04ever on Aug 28, 2023 11:33:12 GMT 1
Is veg asking about an LC cover on a YPVS engine or the other way around? Or YPVS engine in an LC frame?
Post by veg on Aug 28, 2023 11:40:51 GMT 1
Cheers chaps couldn’t remember. 👍
Post by veg on Aug 28, 2023 11:42:45 GMT 1
Rob it’s an Ypvs cover onto an Lc engine in an Lc frame 👍
Post by reedpete on Aug 28, 2023 13:16:22 GMT 1
Don’t forget the clutch actuator…
Post by veg on Aug 28, 2023 13:30:03 GMT 1
Pete does it need a Ypvs one then?
Post by midlifecrisisrd on Aug 28, 2023 13:39:18 GMT 1
YPVS cover doesn't have the facility to fit the clutch actuator so LC engine needs an LC cover I'm afraid
Post by reedpete on Aug 28, 2023 13:40:13 GMT 1
An LC engine needs a clutch push from the left hand case… so not provided for on a YPVS LH cover…
Post by rigga on Aug 28, 2023 15:13:13 GMT 1
Stator side cover ? Yes, can't fit a powervalve cover to a LC Clutch side .... No problem.
Post by dusty350 on Aug 28, 2023 15:17:18 GMT 1
Aircooled E/F (cos of the Cdi pickup) side case fits too. It's Alloy as well May need trimming - not 100% on that
Post by Yogi on Aug 28, 2023 15:49:16 GMT 1
Soz Tim thought it was for a ypvs lump in an Lc 🙈
Post by veg on Aug 28, 2023 16:27:53 GMT 1
Thanks for all the advice chaps, I was having a few moments whilst waiting for the racing to start and contemplating what changes I’m going to do over the winter now I’ve put a fair few miles on the Lc. First thing is a set of Dave’s pipes but they need to match the Tz porting etc.
Post by jon on Aug 29, 2023 13:43:57 GMT 1
I’m surprised no-one has mentioned a hydraulic clutch conversion. I’m sure a YPVS stator cover could have one grafted in. I’m not on about the OEM plastic ones, but a billet cover. I assume that is what veg was interested in?
Post by veg on Aug 29, 2023 14:31:14 GMT 1
Jon it was actually looking at saving more weight by fitting a Ypvs plastic cover instead of the alloy cover, not bothered about it being a hydraulic clutch tbh.
Post by jon on Aug 29, 2023 16:44:37 GMT 1
I would definately chain drill the LC case then. If done right it would look the bollox and still be perfectly safe.
Post by Tobyjugs on Aug 30, 2023 14:50:27 GMT 1
Jon it was actually looking at saving more weight by fitting a Ypvs plastic cover instead of the alloy cover, not bothered about it being a hydraulic clutch tbh. You need to find some one to make you a carbon fiber casing. Its easily done if they have a casing to use for making the mould. The problem is knowing the right person for the job Tim I would also paint it black for stealth reasons.
Post by veg on Aug 30, 2023 14:52:50 GMT 1
Mmmmmm wonder who could possibly assist? 😁👍
Post by dusty350 on Aug 30, 2023 15:24:50 GMT 1
Save yerself a load of cash, by "dropping the kids off at the pool" before going out for a ride" .Probably a bigger weight saving😁
Post by veg on Aug 30, 2023 16:21:29 GMT 1
Completely agree dusty however the disadvantages of that is it doesn’t have the same bragging rights. Yes it is carbon and a one off actually has far more kudos when chatting than yep I saved 6 lbs this morning after having a big crap.
Post by dusty350 on Aug 30, 2023 20:00:04 GMT 1
Only 6lb ?? You need more bran in your diet mate
Post by rigga on Aug 30, 2023 21:08:12 GMT 1
If the splash don't hit your arse, you ain't trying.
Post by peddrotzr on Sept 3, 2023 19:38:03 GMT 1
Completely agree dusty however the disadvantages of that is it doesn’t have the same bragging rights. Yes it is carbon and a one off actually has far more kudos when chatting than yep I saved 6 lbs this morning after having a big crap. As mentioned before, very minimal weight saving, also I dont think that carbon suits the look on these bikes, but thats just me, very sorry! Veg, Save your money for much better things I did make tooling/molds for the YPVS side cover many years ago (2008/09) only ever made two side casings, one for my TZR as everything else is carbon then why not. The other for a friend in Brisbane. Very sorry before anyone asks, I am not making any as I am just far too busy, soz guys. As their isnt a market for this kind of thing as you can see the patio also needs weeding, good job you cant see the rest of garden FFS ! Best rgerads Johnny C.
