Post by billbott on Aug 21, 2023 22:41:48 GMT 1
I have been running a power dynamo on my 4L0 for a good while with the rubber plug caps that came with the kit. The terminals have started to deform so aren’t making a great connection with the plugs - which are the best caps to replace them with? Assume NGK but in black or red, resistor or non resistor? I run standard B8ES plugs so does that mean I need a resistor cap? Thanks in advance, Bill 😊
Post by billbott on Aug 22, 2023 6:43:31 GMT 1
Post by beardy on Aug 22, 2023 7:33:46 GMT 1
I too am running a Power Dynamo on my 4lo since 2019. I started to get a misfire a couple of years ago so I did a lot of reading on the Vape site to find what are the best plug caps to use. I found an article saying to use 1k ohm plug caps. I managed to get some and used them with B8ES plugs. It made no difference to my misfire, eventually diagnosed as the coil/cdi on Muttsnuts dyno. I’ll try and find the link and post it up regarding the plug caps 👍🏻
