Post by jon on Aug 15, 2023 10:40:30 GMT 1
Hi there,
Has anyone got an LC loom to hand to check something out?
I seem to have a spare black earth wire up by the coil end. It has no terminal on the end which makes me suspicious it’s been snipped off?
Can’t see any terminals with the connector missing a wire though?
LC loom
Aug 15, 2023 10:49:18 GMT 1
via mobile
Post by headcoats on Aug 15, 2023 10:49:18 GMT 1
I think it has a ring terminal on the end and bolts to frame If ypvs motor I think it has an extra earth from stator ?
LC loom
Aug 15, 2023 11:02:20 GMT 1
Post by jon on Aug 15, 2023 11:02:20 GMT 1
I think it has a ring terminal on the end and bolts to frame If ypvs motor I think it has an extra earth from stator ? Yes I have the one with the ring terminal, but this is additional? Can’t seee anything on the wiring diagram either? Jon
Post by 4l04ever on Aug 15, 2023 11:10:07 GMT 1
Check it with a meter to see if it is another earth.
Post by linx on Aug 15, 2023 11:39:34 GMT 1
It will be an earth either for the frame or the engine.
LC loom
Aug 15, 2023 12:06:41 GMT 1
Post by jon on Aug 15, 2023 12:06:41 GMT 1
Check it with a meter to see if it is another earth. No need. I’ve taken the insulation off the loom to copy it. Yes it’s on the earth circuit. Jon
LC loom
Aug 15, 2023 12:07:49 GMT 1
Post by jon on Aug 15, 2023 12:07:49 GMT 1
It will be an earth either for the frame or the engine. It’s not that. As I said earlier, it’s already got a frame earth by the coil with a ring terminal on. Jon
Post by 4l04ever on Aug 15, 2023 12:45:08 GMT 1
Does the wire go forwards or backwards?
Post by jon on Aug 15, 2023 13:08:58 GMT 1
Does the wire go forwards or backwards? Forwards. I’ve got another question also please. The connector for the indicator is 3 pin, with one of the wires being yellow with a green tracer to a bullet terminal about 5cm from the connector. This plugs into a matching colour wire which heads off for the cancelling unit. However there is also an earth wire in black beside the bullet terminal. It looks to me to as if in some circumstances the yellow/green wire can be plugged into earth? Maybe a model without the indicator cancelling circuit. It’s a dotted line on some wiring diagrams. I’m thinking of not bothering wiring in the indicator cancelling circuit as 1) I never use it. 2) the reed switch in the speedo is usually broken 3) it strips down the wiring loom. Jon
LC loom
Aug 15, 2023 14:14:01 GMT 1
Post by JonW on Aug 15, 2023 14:14:01 GMT 1
youre right Jon, its for running without the canceller and is standard to be unconnected.
Post by KevtheRev on Aug 18, 2023 8:48:43 GMT 1
Does the wire go forwards or backwards? Forwards. I’ve got another question also please. The connector for the indicator is 3 pin, with one of the wires being yellow with a green tracer to a bullet terminal about 5cm from the connector. This plugs into a matching colour wire which heads off for the cancelling unit. However there is also an earth wire in black beside the bullet terminal. It looks to me to as if in some circumstances the yellow/green wire can be plugged into earth? Maybe a model without the indicator cancelling circuit. It’s a dotted line on some wiring diagrams. I’m thinking of not bothering wiring in the indicator cancelling circuit as 1) I never use it. 2) the reed switch in the speedo is usually broken 3) it strips down the wiring loom. Jon I've always wondered what that mysterious unconnected black wire down near the battery was for . Every day's a schoolday ! Nice one .
Post by JonW on Aug 18, 2023 13:49:48 GMT 1
been talked about a lot over the years on here, its foxed quite a few...
Post by jon on Aug 18, 2023 17:03:11 GMT 1
Forwards. I’ve got another question also please. The connector for the indicator is 3 pin, with one of the wires being yellow with a green tracer to a bullet terminal about 5cm from the connector. This plugs into a matching colour wire which heads off for the cancelling unit. However there is also an earth wire in black beside the bullet terminal. It looks to me to as if in some circumstances the yellow/green wire can be plugged into earth? Maybe a model without the indicator cancelling circuit. It’s a dotted line on some wiring diagrams. I’m thinking of not bothering wiring in the indicator cancelling circuit as 1) I never use it. 2) the reed switch in the speedo is usually broken 3) it strips down the wiring loom. Jon I've always wondered what that mysterious unconnected black wire down near the battery was for . Every day's a schoolday ! Nice one . Sorry, no not that one. Read the whole thread. Jon
LC loom
Aug 19, 2023 10:44:08 GMT 1
Post by KevtheRev on Aug 19, 2023 10:44:08 GMT 1
I've always wondered what that mysterious unconnected black wire down near the battery was for . Every day's a schoolday ! Nice one . Sorry, no not that one. Read the whole thread. Jon Ah , sorry Jon , must've gotten my wires crossed . Any idea what that black wire with the male bullet connector , but not connected to anything , down near the battery is for ??
Post by jon on Aug 19, 2023 11:45:42 GMT 1
Sorry, no not that one. Read the whole thread. Jon Ah , sorry Jon , must've gotten my wires crossed . Any idea what that black wire with the male bullet connector , but not connected to anything , down near the battery is for ?? I seem to remember this topic discussed some time ago. From memory the most likely was something fitted on non euro bikes as an earth. Jon
Post by 4l04ever on Aug 19, 2023 12:25:53 GMT 1
Sorry, no not that one. Read the whole thread. Jon Ah , sorry Jon , must've gotten my wires crossed . Any idea what that black wire with the male bullet connector , but not connected to anything , down near the battery is for ?? That black wire is for the Euro bikes with no Self Cancelling unit. It is connected instead of the Yellow Green wire.
LC loom
Aug 19, 2023 12:53:02 GMT 1
Post by jon on Aug 19, 2023 12:53:02 GMT 1
Ah , sorry Jon , must've gotten my wires crossed . Any idea what that black wire with the male bullet connector , but not connected to anything , down near the battery is for ?? That black wire is for the Euro bikes with no Self Cancelling unit. It is connected instead of the Yellow Green wire. No it’s not that as said in my 5th post on this thread. Jon
LC loom
Aug 19, 2023 15:07:58 GMT 1
Post by KevtheRev on Aug 19, 2023 15:07:58 GMT 1
I don't have indicators on my LC . The law here is , you don't have to have 'em , but if you do they have to work .
