Post by midlifecrisisrd on Aug 20, 2023 16:38:34 GMT 1
I'd hope it's open 😬
Post by arrow on Aug 20, 2023 18:21:15 GMT 1
Closed is very important once the full bore position has been established.
Please send a photo at closed throttle.
naich
Post by naich on Aug 20, 2023 19:43:44 GMT 1
That's closed.
Post by arrow on Aug 20, 2023 20:20:55 GMT 1
It's still too high there, but how did you make it so much better than it was before?
naich
Post by naich on Aug 21, 2023 11:35:25 GMT 1
It's still too high there, but how did you make it so much better than it was before? I think I can live with that, or do you think it's far enough off to worry about? I fixed it by chopping about 8mm from the outer sleeve of the cable going to the pump.
Post by arrow on Aug 21, 2023 12:32:16 GMT 1
It will smoke a lot more in the lower and mid range and use more than a normal amount of oil. But if you can live with that...
naich
Post by naich on Aug 21, 2023 13:33:59 GMT 1
I'd rather err on the side of a bit more smoky at the moment. As long as it's not bad enough to start fouling up the plugs I can live with that. I'll see how it goes. Thanks for your help.
