Post by hopper350 on Aug 8, 2023 19:47:24 GMT 1
Hi, I could do with the measurement of the square end on the inner speedo cable that goes into the f2 clocks, any help much appreciated. cheers Paul
Post by shaunthe2nd on Aug 8, 2023 20:01:33 GMT 1
Im not home otherwise would measure for you but all the cable entries are the same for the vast majority of the jap clocks of that era. Probably around 3mm square at a guess. Hopefully someone can measure for you.
Post by alankelly on Aug 8, 2023 22:23:54 GMT 1
Hope this helps Looks to be 2.5 to 2.6mm square Best wishes Al
