Post by wr40099 on Aug 1, 2023 22:25:12 GMT 1
Hi guys. What are you using to clean carbs that have been left unused for a few months ? I bought super plus from a ‘reputable supplier’ to start my wr.
Ran it up a few times in the shed and all seemed well. Ran the carb dry and drained it and it’s stood for approx 3 months due to cottage renovations. Why are the internals covered in a green vegetational filth ?
What are you using for ultrasonic cleaners ? Best suggestions please based on experience .
Thanks in advance.
red998
Post by red998 on Aug 2, 2023 9:46:58 GMT 1
You can get a specific cleaner if you use an ultrasonic cleaner. My bike stood for seven years outside but was covered up and upon rebuilding the whole bike I used carb. cleaner from Toolstation, unfortunately, they no longer stock it, that worked perfectly though.
The other day I bought some "Mechanic In Bottle" from eBay and that is what I am using. Similar to above you pour some in the tank and it cleans the fuel system. This is on sale in Toolstation but only in the small bottle size at £8.99, as it was then. The larger bottle via an eBay seller is a better value.
Post by wr40099 on Aug 5, 2023 9:11:37 GMT 1
Thanks for that, I’ll have a look. I was also looking for recommendations for ultrasonic cleaners.
red998
Post by red998 on Aug 6, 2023 9:53:29 GMT 1
For me, it would be the biggest cleaner I could afford as it can then be used for all manner of parts. If it's just for carbs then a small stainless steel one should do the job of about a litre or so depending on its dimensions.
Post by wr40099 on Aug 9, 2023 17:17:24 GMT 1
Thanks again mate, I’ll have a look round on the interweb, see what’s what.
Post by stusco on Aug 9, 2023 19:03:36 GMT 1
If its just one carb completely strip and clean manually it will take half an hour elbow use grease kitchen cleaner or brake cleaner and a tooth brush You will still need to strip it using an ultra sonic
