Post by Tobyjugs on Jul 30, 2023 16:46:03 GMT 1
I've got a standard swing arm fitted to an LC and i would like to use a rear wheel paddock stand. I dont want to mod the swing arm, is there any aftermarket chain tensioners i can fit to the bike with the facility to use a rear paddock stand? Cheers in advance
Post by 4l04ever on Jul 30, 2023 17:25:31 GMT 1
On my mates LC, we drilled and tapped into the ends of the rear wheel spindle, then bolted in small bobbins. Works fine and you can just remove them when not needed.
Only downside is you can't fit the cotter pin, so may have to use a nylock nut instead.
Post by Yogi on Jul 30, 2023 17:48:15 GMT 1
You could cut the locating cups on the paddock stand and weld them on sideways ,, maybe đ¤
Then use on the existing tensioners đĩâđĢ
Post by midlifecrisisrd on Jul 30, 2023 17:54:07 GMT 1
On skinny swing arm bikes I use a front paddock stand as they aren't as wide
The 2 rubber covered pins on each side go under the swing arm nicely
Post by Tobyjugs on Jul 30, 2023 18:44:53 GMT 1
On skinny swing arm bikes I use a front paddock stand as they aren't as wide The 2 rubber covered pins on each side go under the swing arm nicely Steve I will have to try that one out.
Post by donkeychomp on Jul 30, 2023 21:15:09 GMT 1
Me too. I have a cheapo eBay one and it works a treat on skinnier swing arms.
Post by Tobyjugs on Aug 1, 2023 20:17:05 GMT 1
I tried the front paddock stand but it doesn't work because the brake rod is directly under the swing arm.
Post by midlifecrisisrd on Aug 1, 2023 20:47:15 GMT 1
Bugger âšī¸
Post by JonW on Aug 2, 2023 0:24:36 GMT 1
Funny thing... the bike came with a centre stand... I'll get me coat!
