Post by bruceybonus on Jul 29, 2023 16:40:55 GMT 1
Does anyone know what headlamps may fit inside a N1/N2 black plastic headlamp shell?
Can't seem to find a genuine YPVS N1/N2 second hand UK one.
See plenty of cheep Fleabay replacements but I want it to sit inside the original plastic cover and not sure if these will or not.
ATB
Bruce
Post by midlifecrisisrd on Jul 29, 2023 17:38:16 GMT 1
Hi
XJR400, r1z250 and check rz250 as the jap spec ypvs bikes were the same headlight
Post by bruceybonus on Jul 29, 2023 23:24:43 GMT 1
Hi XJR400, r1z250 and check rz250 as the jap spec ypvs bikes were the same headlight Steve Thanks Steve
Post by bruceybonus on Jul 30, 2023 0:27:04 GMT 1
So does a RD250/350 LC (4LO/4L1) lens assembly will fit inside a N1/N2 (29L-84330-01) black plastic cover?
ATB Bruce
Post by midlifecrisisrd on Jul 30, 2023 10:53:52 GMT 1
So does a RD250/350 LC (4LO/4L1) lens assembly will fit inside a N1/N2 (29L-84330-01) black plastic cover? ATB Bruce I've ever tried an lc headlight and rim in an LC bowl so can't answer that I'm afraid The actual LC glass is the same as ypvs so when I've been stuck I have bought a Euro ypvs headlight, smashed and removed the glass (be careful, the reflector inside is very delicate, even your finger can damage it) then removed a glass from an LC one and silicone it in (remove the cover over the lamp on the Euro one, just pulls off when you remove the glass) Steve
Post by bruceybonus on Aug 2, 2023 14:30:13 GMT 1
UPDATE: The 4L0/4L1 LC headlamp assembly fits inside the YPVS black plastic cover ..... result!
