Post by headcoats on Jul 18, 2023 7:53:53 GMT 1
Smeg dishwasher has thrown a fit. Buttons don't work and sounds like the pump is staying on
Post by headcoats on Jul 18, 2023 7:57:50 GMT 1
Post by reedpete on Jul 18, 2023 18:04:16 GMT 1
Yes, either the sump sensor is defective, the pump switch contact is permanently on or the leak tray is full… but normally if it’s just the leak tray that’s full then you will get an error code or blink code to say as much.. If you can fathom a running fault on an LC you should be able to handle a dishwasher 😉
Post by headcoats on Jul 18, 2023 19:01:22 GMT 1
Well I took the skirting board off in preparation for a fiddle ,tried on off button again and it seems to have righted itself Put it through a short 27min wash and it worked ...
So now I don't trust it LOL
It's a built in washer aswell
Post by headcoats on Jul 19, 2023 17:12:49 GMT 1
Went on longer wash and threw a fit again Booger
Post by steve h on Jul 19, 2023 21:42:43 GMT 1
Only thing I know about dishwashers is.... wear marigolds to keep your hands problem free. If I don't use them in my capacity as "washer up" they start cracking and get sore. The dog is the pre-wash, and removes solids and gravy and even residues from curries and the like from all the pots and plates and even has the capacity to pre wash a 2 gallon jam/chutney/tomato-pesto, pan.
Post by headcoats on Jul 19, 2023 22:06:14 GMT 1
There is a leak underneath which I guess has tripped something out but looked on the documents for when we had it and is now 8 years old !
Post by reedpete on Jul 20, 2023 0:24:24 GMT 1
There is a leak underneath which I guess has tripped something out but looked on the documents for when we had it and is now 8 years old ! There will be a float switch in the catch tray.. to do exactly that..if you empty the tray out and fix the leak then should be up and running.
Post by headcoats on Jul 20, 2023 1:37:20 GMT 1
Found the leak ,it's a small diameter grey pipe near the front It was only leaking when switched on doing a wash so not noticeable otherwise
Need to find the correct replacement and how to get in there ?
Lie the washer on it's back and unclipped the base ?
Post by reedpete on Jul 20, 2023 4:32:04 GMT 1
There is bound to be a youtube for how to access stuff on your particular model. But yes one way or another , unscrew panels to access. Putting a towel on the floor and tiling onto its back or side wouldn’t be unheard of !
Post by headcoats on Jul 20, 2023 14:20:09 GMT 1
Tilted the washer and got bottom cover off and got to the hose,it had split ! Got a replacement on fleabay £7.99 posted ! If it had been in a Yamaha bag it would have been £94 LOL
