How to make a leak down test kit
Jul 4, 2023 23:05:59 GMT 1
crogthomas, abar121, and 3 more like this
Post by jimblob on Jul 4, 2023 23:05:59 GMT 1
Hi guys & gals,
I’m currently part way through the restoration of a rd350r YPVS (1995) Brazil built bike. It’s taking a loooong time but has started to progress quite quickly over the last few weeks. Hopefully when it’s finished it will look like something distantly related to an ‘N’ type model!!!
I’ve hassled a lot of people on this forum for their invaluable help and advice so I thought I’d post something that might help someone else for a change 😀
I wanted to try and make a leak down test kit but all the instructions I found involved cutting copper pipe, soldering, making blanking plates, rubber seals, etc. After watching a few you tube videos and searching through this forum i started searching flea bay for the parts I needed. I have no experience of soldering pipes etc so wanted it to be as simple as possible to put together.
I’ve tried to add the link for each eBay item at the bottom of the page. I hope they work.
To seal up the intake and exhaust ports (intake rubbers fitted) I used four ‘freeze expansion’ rubber plugs (31 - 34mm).
I then found a 30psi pressure gauge with a ‘1/8 BSP bottom entry’ (fnar fnar) whatever that means.
I then obtained the following fittings -
1/8 bsp x3 way female tee
1/8 bsp x 1/4” hose tail (x2)
1/4” brass hose tail connector
Soft rubber tubing (5mm x 8mm)
Rubber bungs (x2). One with hole and one without. I bought size 13 which worked ok but I think size 15 would be better.
A blood pressure bulb type pump
And some PTFE tape for sealing water/gas
I also obtained a 1/8 bsp Schrader valve so I could use a bicycle pump as well in case the blood pressure pump wasnt up to the job!!
905B174D-0EE5-4CE3-81A8-166263BADCC0 by James Smith, on Flickr
I used the ptfe tape to attach the pressure gauge to the top of the x3 way tee and to also attach the hose tails either side of the tee piece. I used a piece of the rubber tubing to attach the blood pressure pump to one side of the tee joint.
I then attached the rest of the rubber hose to the other side of the tee joint and then attached the double ended hose tail connector to the end of the tube. The rubber bung with the hole in it was then pushed over the end of the double hose tail connector. The attached rubber bung was inserted into one of the balance pipe joints and the solid rubber bung was placed in the other balance pipe joint to seal it.
After inserting the spark plugs and ensuring all bungs were a snug fit I finally pressure tested the engine.
Unfortunately the engine didn’t hold any pressure over 2-3 psi but after squirting soapy water everywhere I found x3 leaks around the intake rubbers where it meets the Reed valves. I had to keep pumping to keep the pressure at around 5 psi to test the rest of the engine but fingers crossed I couldn’t find any other leaks 😬
E978F495-5F85-4592-B951-C0B6FBA38AB9 by James Smith, on Flickr
I did test the equipment on its own and it worked perfectly with no leaks at all!!!
Total cost for all the bits is approx £50.00.
I’m hoping the above info may be of some use to someone in need of a leak down test kit. If I managed to put it all together anyone can.
Cheers
Jim
Freeze expansion rubber plugs
www.ebay.co.uk/itm/285308448583?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=JoSkOPTTSgG&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/133957973574?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=NixkHUICQ1K&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/110897874412?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=NixkHUICQ1K&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/121132816124?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=NixkHUICQ1K&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/121137623807?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=NixkHUICQ1K&sssrc=4429486&ssuid=&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/265285771363?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=ehjYaSnpSwS&sssrc=4429486&ssuid=x-kJgxS3TJ-&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/144648261255?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=YI5yZF5vTzy&sssrc=4429486&ssuid=x-kJgxS3TJ-&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/203758502130?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=vsPpxoifTze&sssrc=4429486&ssuid=x-kJgxS3TJ-&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/251466811320?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=dw9mkD0pQYS&sssrc=4429486&ssuid=x-kJgxS3TJ-&var=&widget_ver=artemis&media=COPY
www.ebay.co.uk/itm/254334745408?mkcid=16&mkevt=1&mkrid=711-127632-2357-0&ssspo=BmpHqVtnQD6&sssrc=4429486&ssuid=x-kJgxS3TJ-&var=&widget_ver=artemis&media=COPY
Cheers
Jim
