Post by jon on Jun 20, 2023 21:38:24 GMT 1
Hi all, I’ve just noticed there are 2 different F/N2 seat bases. Maybe one is Japanese and one is Brazillian? It’s a bit had to see from the photo but the two catches are held on in a different way. One has studs in the base and then the catch is held on with nuts, the other has threaded holes in the base and the catch is held on with screws. What are the merits of either. The seat I’ve sent to be recovered has the threaded inserts. At this stage I could loctite screws in from behind to work in the same way as the studs. Jon
YPVS seat
Jun 20, 2023 22:07:37 GMT 1
via mobile
Post by midlifecrisisrd on Jun 20, 2023 22:07:37 GMT 1
Both have their benefits and weaknesses
The weaknesses happen with corrosion
If the captive nuts seize you can't get into them
If the studs seize they either shear or the captive plate rots out so they just spin. Had to make new ones for my guilly as they had rotted
As long as you have left the bolts in either should be fine, don't think you will have rot issues
YPVS seat
Jun 20, 2023 22:21:36 GMT 1
via mobile
Post by veg on Jun 20, 2023 22:21:36 GMT 1
Thank god for that thought this was going to be about the god awful gully seat for Ypvs was preparing the eye bleach. 👍
YPVS seat
Jun 20, 2023 22:30:40 GMT 1
via mobile
veg likes this
Post by midlifecrisisrd on Jun 20, 2023 22:30:40 GMT 1
Thank god for that thought this was going to be about the god awful gully seat for Ypvs was preparing the eye bleach. 👍 F*ck off Steve 🤣🤣🤣
YPVS seat
Jun 20, 2023 22:57:21 GMT 1
via mobile
Post by veg on Jun 20, 2023 22:57:21 GMT 1
Post by jon on Jun 20, 2023 23:40:21 GMT 1
Both have their benefits and weaknesses The weaknesses happen with corrosion If the captive nuts seize you can't get into them If the studs seize they either shear or the captive plate rots out so they just spin. Had to make new ones for my guilly as they had rotted As long as you have left the bolts in either should be fine, don't think you will have rot issues Steve I don’t think corrosion will be an issue. The amount of miles I do an in fair weather today is a fraction of what I did when 17. When bikes/scooters were your only transport they got used in all weathers for lots of miles. Jon
