Post by skydemon on Jun 13, 2023 15:22:41 GMT 1
Afternoon chaps. I have a set of 4L0 carburettors that have been blanked off with a small bolt and I’m re-introducing an oil pump (thanks Arrow it is amazing). Does anyone have a pair of the little inserts that the oil pipe clips onto or does anyone know where I can get some. As always, I really appreciate your help. P
Post by lcmarky on Jun 15, 2023 10:31:51 GMT 1
Norbo would be my first check. You can just use a brass barb with the correct thread if it's threaded or machine your own, but I'd check the ID of the standard inlet to try and keep it original specs. Also only use the pukka Yamaha oil pipe and clips as it's designed to manage the heat etc and not collapse/expand..
