Post by lancey007 on Jun 11, 2023 13:03:56 GMT 1
Is there a tool to remove the fork stauncher on my RD, the forks fully loaded with the spring etc but the bolt is just spinning round?..
thanks..
Post by chrisg on Jun 19, 2023 19:26:38 GMT 1
Ive always managed with a impact gun.
Post by steve63 on Jun 20, 2023 12:49:27 GMT 1
Is there a tool to remove the fork stauncher on my RD, the forks fully loaded with the spring etc but the bolt is just spinning round?.. thanks.. The damper rod inside will just be spinning with the screw in the bottom. You need to jam it with something. Even something like a broom handle maybe sanded to a bit of a rounded point is sometimes enough to hold it. A piece of round bar again ground to a rounded point, put on the floor and lower the fork leg onto it and apply pressure while you undo the screw in the bottom. I had the discussion recently about these screws being threadlocked from new and I'm pretty sure that the ones I've undone were. On my GSXR1100 the damper rod had a recessed hexagon in it and I found a brass electrical fitting that fitted it and fastened it to a T shaped tube, used it once and it's still hanging up in the garage somewhere. The LC's are just a round recess. I don't know about RD's.
