Post by lukey1965 on Jun 8, 2023 10:30:09 GMT 1
Could anybody please post some pics showing correct fitment of bush and top hat washer on LC2 footrest exhaust hanger ....
Post by lukey1965 on Jun 12, 2023 14:41:14 GMT 1
Can anybody help please ??
I gave had 2 completely conflicting responses from 2 well regarded people....
Post by midlifecrisisrd on Jun 12, 2023 15:12:45 GMT 1
Hi The Lc2 doesn't use the Bush and top hat like the LC It's a one piece metal edged Bush with a bonded in metal centre There is a rubber backed stepped washer on the outer edge too Some pics off ebay Steve
Post by lukey1965 on Jun 12, 2023 17:04:00 GMT 1
Many thanks for that, great help. To confirm, the larger part of the metal insert goes on the inside of the hanger ?? IOf so, does it sit flush with the inside hanger face please ?? Hi The Lc2 doesn't use the Bush and top hat like the LC It's a one piece metal edged Bush with a bonded in metal centre There is a rubber backed stepped washer on the outer edge too Some pics off ebay Steve
Post by crogthomas on Jun 12, 2023 17:08:29 GMT 1
AS per the photo, the larger diameter part of the central steel bobbin sticks out proud of the surface of the hanger. The idea is that it keeps the exhaust away from the hanger.
Post by midlifecrisisrd on Jun 12, 2023 17:13:01 GMT 1
When the Bush is pressed into the hanger it fills the recess completely
The outer skin of the Bush will sit flush with the inside edge, the protruding top hat section will sit about 3mm inward towards the wheel
Post by LC_BOTT on Jun 12, 2023 17:38:30 GMT 1
I think they are also marked 'top' to help installation, as they are differing thickness around the inner bush (if that makes sense)
Post by freddie19 on Jun 12, 2023 20:28:34 GMT 1
Here's a shot from above showing the bush with my Allspeeds fitted.👍
Post by lukey1965 on Jun 15, 2023 18:14:36 GMT 1
Many thanks all.
Post by JonW on Jun 16, 2023 2:13:02 GMT 1
Interestingly these washers (90209-08249) are different to the US version which are more of a flat washer.
I guess any washer would work, the bolt head will just stick out slightly more. These do have rubber backing though, I guess to stop it eating the alloy footrest?
Post by tucktonite on Oct 5, 2023 17:46:35 GMT 1
Sorry to resurect, but which way do these bushes (lc2) come out? Cheers.
Post by andy748 on Oct 5, 2023 18:24:16 GMT 1
Easiest way is junior hacksaw the rubbers out, obviously removing the blade and inserting through the gap in the rubber, once the centre part is sawn out, do one cut through the metal bush, it's really thin and pressed into the hanger, just be careful not to damage the alloy hanger. Then you can prise it out with a sharp edged screwdriver. It's the easiest way, I find. Andy.
Post by tucktonite on Oct 5, 2023 19:08:13 GMT 1
Easiest way is junior hacksaw the rubbers out, obviously removing the blade and inserting through the gap in the rubber, once the centre part is sawn out, do one cut through the metal bush, it's really thin and pressed into the hanger, just be careful not to damage the alloy hanger. Then you can prise it out with a sharp edged screwdriver. It's the easiest way, I find. Andy. Nice one, after trying the stud/socket approach, I've come to the same conclusion.
Post by tucktonite on Oct 5, 2023 19:09:53 GMT 1
And the new ones go In from outside towards the wheel?
Post by andy748 on Oct 6, 2023 8:50:03 GMT 1
If memory serves i did mine from the back as it's square on, pressed them in with me vice and a big socket? Andy.
