Post by wonkywheel on May 26, 2023 18:49:42 GMT 1
The LC fired up this evening after a full engine rebuild. Running 50:1 tank mix. Sounds great, really smooth and gears selecting. I was about to bleed the oil pump lines when I noticed the main oil tank feed pipe was leaking on the pump inlet union, despite having a genuine clip. Over the years it has swelled. I tried to cut it back, but now its too short. It a non- genuine pipe, which I tried to replace with a genuine one, but not available anymore. Where might I source a decent oil resistant pipe and the correct diameter? And what type of clips are you using because the Yamaha one doesn’t seem to clamp the pipe very well. I don’t want to use a cheap pipe which expands with heat and causes air bubbles. Obviously I need a pipe that is made to a certain specification like a hydraulic pipe. Advice and links very much appreciated. Have a great bank holiday weekend
Post by linx on May 26, 2023 18:57:06 GMT 1
I think Yambits do them.
Post by oldelsieboy on May 26, 2023 19:03:10 GMT 1
The LC fired up this evening after a full engine rebuild. Running 50:1 tank mix. Sounds great, really smooth and gears selecting. I was about to bleed the oil pump lines when I noticed the main oil tank feed pipe was leaking on the pump inlet union, despite having a genuine clip. Over the years it has swelled. I tried to cut it back, but now its too short. It a non- genuine pipe, which I tried to replace with a genuine one, but not available anymore. Where might I source a decent oil resistant pipe and the correct diameter? And what type of clips are you using because the Yamaha one doesn’t seem to clamp the pipe very well. I don’t want to use a cheap pipe which expands with heat and causes air bubbles. Obviously I need a pipe that is made to a certain specification like a hydraulic pipe. Advice and links very much appreciated. Have a great bank holiday weekend The original pipe is NLA but has been superseded by www.fowlersparts.co.uk/parts/view/90445090F6OEB
Post by steeley on May 26, 2023 19:18:03 GMT 1
How about this company . www.pvctubeonline.co.uk/hobbypro_yellow_petrol_tube.htm . I would look at the tygon tubing , though i have used the pvc tubing from the oil tank to the pump . It goes hard over the years though . Clips , a mate picked a selection up off ebay , they were the 3 spike type 2 one side with one the other .
Post by dusty350 on May 26, 2023 19:48:15 GMT 1
I bought the oil hose that Nigel has linked for you. Fowlers had it in stock for next day delivery. It's genuine Yam and fits as it should. Wouldn't bother with anything else imo. Dusty
Post by wonkywheel on May 27, 2023 12:13:37 GMT 1
The LC fired up this evening after a full engine rebuild. Running 50:1 tank mix. Sounds great, really smooth and gears selecting. I was about to bleed the oil pump lines when I noticed the main oil tank feed pipe was leaking on the pump inlet union, despite having a genuine clip. Over the years it has swelled. I tried to cut it back, but now its too short. It a non- genuine pipe, which I tried to replace with a genuine one, but not available anymore. Where might I source a decent oil resistant pipe and the correct diameter? And what type of clips are you using because the Yamaha one doesn’t seem to clamp the pipe very well. I don’t want to use a cheap pipe which expands with heat and causes air bubbles. Obviously I need a pipe that is made to a certain specification like a hydraulic pipe. Advice and links very much appreciated. Have a great bank holiday weekend The original pipe is NLA but has been superseded by www.fowlersparts.co.uk/parts/view/90445090F6OEB Ordered... many thanks
Post by wonkywheel on May 27, 2023 12:15:16 GMT 1
I bought the oil hose that Nigel has linked for you. Fowlers had it in stock for next day delivery. It's genuine Yam and fits as it should. Wouldn't bother with anything else imo. Dusty Absolutely agree
neil
my 125
Post by neil on May 27, 2023 12:34:28 GMT 1
I got the pipe from Norbo
Post by KevtheRev on May 29, 2023 10:06:46 GMT 1
I got the clear lines off Norbo . At least you can see if it's getting oil or not .
Post by JonW on May 29, 2023 13:38:27 GMT 1
Cue difference of opinion...
Post by cb250g5 on May 29, 2023 13:47:36 GMT 1
I got the clear lines off Norbo . At least you can see if it's getting oil or not . Light blue touchpaper.... I also run clear lines. You can see if they have oil in them, you can't see if the pump is moving any towards the motor. I bought yards of the stuff years ago. It goes hard after a few years, so I just swap it out for some more.
Post by KevtheRev on May 29, 2023 14:06:06 GMT 1
I got the clear lines off Norbo . At least you can see if it's getting oil or not . Light blue touchpaper.... I also run clear lines. You can see if they have oil in them, you can't see if the pump is moving any towards the motor. I bought yards of the stuff years ago. It goes hard after a few years, so I just swap it out for some more. Lol ! Haven't seen any bubbles and do keep an eye on how smoky it is on start-up . Not much more you can do really . (Other than having Arrow work his Black Art on the pump ; )
Post by jon on May 30, 2023 13:37:13 GMT 1
How about this company . www.pvctubeonline.co.uk/hobbypro_yellow_petrol_tube.htm . I would look at the tygon tubing , though i have used the pvc tubing from the oil tank to the pump . It goes hard over the years though . Clips , a mate picked a selection up off ebay , they were the 3 spike type 2 one side with one the other . +1 for Tygon. My mate used to use it at work. He gave me some a while back, and I found it to be the best I’ve ever used. Will be buying some more when it runs out. Jon
