Post by simonlc on May 8, 2023 18:13:08 GMT 1
Ok I know it’s been talked about before but got the usual clutch slip on full power. What upgrades do people do? EBC plates and 3 x stronger springs seem to be the way to go.
Post by 4l04ever on May 8, 2023 19:18:26 GMT 1
Try the EBC DRC043 kit. Wider friction plates and slightly uprated springs.
dc12
Don’t get eliminated!
Post by dc12 on May 8, 2023 22:20:47 GMT 1
I’ve had great success with Vesrah VC-281 plates with the stock springs. As stated above the friction material is wider so you have to remove the rubber cushion rings if still present.
Post by elsiefan on May 9, 2023 0:24:51 GMT 1
Try the EBC DRC043 kit. Wider friction plates and slightly uprated springs. +1 Fitted mine easily (remove the rubber cushion rings if present) and no clutch slip issues now. Dave at Mutts Nutts sells the EBC kits.
Post by stusco on May 9, 2023 9:19:03 GMT 1
I got a driveline kit from Dave as ebc wasn’t available it has the same spec
Post by tacky1 on May 10, 2023 4:27:27 GMT 1
Try the EBC DRC043 kit. Wider friction plates and slightly uprated springs. I run this in all mine. Plus 3 new oem springs and 3 of the ebc springs. Top job and zero slipping.
Post by crogthomas on May 14, 2023 8:55:41 GMT 1
Ok I know it’s been talked about before but got the usual clutch slip on full power. What upgrades do people do? EBC plates and 3 x stronger springs seem to be the way to go. Is this for a standard or tuned engine? If standard, then just fitting a new stock clutch should be fine. Probably for a tuned engine too.
Post by stusco on Aug 21, 2023 21:12:42 GMT 1
Ive got standard springs (all six)on mine it’s tuned clutch is nice and light compared to hd springs no slip either
Post by JonW on Aug 22, 2023 2:09:02 GMT 1
Isnt the HD kit just a kit with plates for a bigger yam with wider frictions/steels and slightly uprated springs?
Im wondering if you just bought the bigger bikes standard kit would it be cheaper for the same thing?
I say that as you probably dont want the HD springs, horrid things...
Ive not looked... im just idly wondering...
Anyway... always fit new springs. The OEM ones go baggy really quickly and are cheap. I found when i measured a bunch of old clutches that the plates were all in spec, it was the springs that were trashed and probably causing the slip.
Post by elsiefan on Aug 22, 2023 11:56:11 GMT 1
Isnt the HD kit just a kit with plates for a bigger yam with wider frictions/steels and slightly uprated springs? Im wondering if you just bought the bigger bikes standard kit would it be cheaper for the same thing? I say that as you probably dont want the HD springs, horrid things... Ive not looked... im just idly wondering... Anyway... always fit new springs. The OEM ones go baggy really quickly and are cheap. I found when i measured a bunch of old clutches that the plates were all in spec, it was the springs that were trashed and probably causing the slip. Like tacky1 and a few others I also run 3 x HD and 3 x OEM springs, clutch doesn't slip nor require you to be Charles Atlas to operate it!
Post by JonW on Aug 22, 2023 13:46:55 GMT 1
It was always a 'thing' to do the 3+3 thing with the springs, but really if you fit brand new OEM springs its often more than man enough for the job. They are a wear part really.
I have a full compliment of uprated springs on one of my bikes, even with other levers its not ideal. But there are other things you can do to lighten the lever of course.
Post by elsiefan on Aug 23, 2023 12:10:09 GMT 1
The EBC kit came with 6 HD springs and I have no spare OEM springs to hand, so using a 50/50 mix of springs (as suggested by Dave W at Mutts) seemed a viable option. I'm sure there are lots of options, and if one finds one that works, then it's smiles all round
