hexta
Post by hexta on Apr 17, 2023 11:26:01 GMT 1
Hello, I found this damper in my parts bin, believe it's an Øhlins. Not sure if to rebuild it or get a new YSS or similar. Have tried it on a rolling chassis, jumping down on the seat it feels a lot better than the stock shock. What do you think? Run it as is, Rebuild(cost estimate), or buy new?
Post by Tobyjugs on Apr 17, 2023 12:14:02 GMT 1
Rebuild and use.
Post by steve63 on Apr 17, 2023 12:53:05 GMT 1
As above.
Post by srhiskx on Apr 17, 2023 17:19:07 GMT 1
Run the Ohlins!
Post by Gitram on Apr 17, 2023 20:33:14 GMT 1
ride it until it bursts then get it rebuilt.. if it's not broken now, why spend the money up front?
marti
Post by shaunthe2nd on Apr 17, 2023 20:56:47 GMT 1
I'd do a cosmetic refurb on it and re-use.
Post by donkeychomp on Apr 17, 2023 22:00:24 GMT 1
Ohlins? Use it!
Post by Chewie01 on Apr 17, 2023 22:12:56 GMT 1
That's quite the colour scheme you've got going on there. Purple and yellow is sure going to catch the eye.
hexta
Post by hexta on Apr 18, 2023 10:12:50 GMT 1
The Öhlins shall then be run! It does seem a bit soft though, maybe a stronger spring should be fitted? Have turned the tensioner ring quite a bit down And, is rebuilding something best left to professionals?
hexta
Post by hexta on Apr 18, 2023 10:16:15 GMT 1
That's quite the colour scheme you've got going on there. Purple and yellow is sure going to catch the eye. easily noticed
