odie
Post by odie on Apr 3, 2023 18:16:33 GMT 1
Hi gents Anyone wired up an in line temp sender from Koso. There are 2 wires a green and yellow, just wondering if they will work with a standard temp gauge for a YPVS.
Cheers
crogthomas
In his shed....
Post by crogthomas on Apr 3, 2023 20:29:08 GMT 1
It seems unlikely. Do you have the spec of the Koso sensor?
odie
Post by odie on Apr 4, 2023 16:29:34 GMT 1
After measuring the resistance for the koso and the std temperature sender in boiling water they are not compatible. Std is around 30 ohms at 100 deg and the Koso is 1K ohms. However the standard temp sender did fit in the Koso adapter so will try that. May need a neutral wire to get it to work but easily done
