Post by 4l04ever on Mar 16, 2023 22:32:34 GMT 1
I spotted a that the o-ring on the OEM one has some orangey/brown sealant/adhesive under it to hold it in. It is not a full seal by the look of it.
Has anyone got a new Tourmax one to verify if there is any sealant under the o-ring?
Post by elsiefan on Mar 17, 2023 2:17:32 GMT 1
I do have a new Tourmax one, but it's already fitted and I didn't look under the o-ring seal, just checked it had one and bolted it on. Sorry.
stoney
Post by stoney on Mar 17, 2023 9:11:15 GMT 1
Yes, Tourmax has sealant holding the o ring underneath.
Post by 4l04ever on Mar 18, 2023 0:48:13 GMT 1
I wonder what the sealant is for, as the LC tap as 4 tight spots around the o-ring groove to hold it in???
Post by rodney5501 on Sept 13, 2023 18:26:00 GMT 1
Is the tourmax tap worth buying thanks
Post by muttsnuts on Sept 13, 2023 20:11:37 GMT 1
Is the tourmax tap worth buying thanks they are identical to the OEM tap
Post by tacky1 on Sept 14, 2023 23:38:21 GMT 1
Is the tourmax tap worth buying thanks 100% worth buying. I’m using 2 of them and they are excellent.
Post by JonW on Sept 15, 2023 2:32:45 GMT 1
Is the tourmax tap worth buying thanks Plenty of us use the Tourmax, in fact most of us. Lots of threads about it on here. Always worth a search if wondering about stuff like this as you'll find the info rightaway.
Post by JonW on Sept 15, 2023 2:33:27 GMT 1
They must have had the seal pop out, but it really shouldnt. hmm..
Post by reedpete on Sept 15, 2023 3:06:23 GMT 1
Or its belt and braces wrt the seal against the tap casting surface. The steel of the tank is probably a better compression seal surface.
Post by jon on Sept 20, 2023 22:32:36 GMT 1
I do wonder whether it’s an installation thing? Maybe the sealant oozes out when the tap is fitted and forms a seal with the tank to take up any discrepancies?
Post by Tobyjugs on Sept 21, 2023 3:17:23 GMT 1
I think it is just to keep the rubber ring in place when fitting.
Post by jon on Sept 30, 2023 12:34:37 GMT 1
I think it is just to keep the rubber ring in place when fitting. As Rob said, there are 4 tight spots in the o ring groove to keep the o ring in, so I don’t think it’s for this. As I said before, I think it’s a first time fit thing with it squishing out to form a seal with the tank if I had to guess? Jon
