Post by JonW on Feb 9, 2023 13:06:37 GMT 1
Post by reedpete on Feb 9, 2023 13:10:27 GMT 1
Guesses by me are either Rear facing cameras (virtual mirror) or EGT
Post by Chewie01 on Feb 9, 2023 13:22:00 GMT 1
My guess would be temperature readouts. As this looks like an RD500 I would suspect it would show the temperature of the front and rear cylinders.
Post by lcmarky on Feb 9, 2023 17:47:54 GMT 1
temp gauges..
Post by muttsnuts on Feb 9, 2023 19:29:49 GMT 1
that's an RD500, they are attached the the mirror stems, so not cameras, I reckon temp gauges (front bank and rear bank), if not, then EGT read outs, again front and rear
Post by Norbo on Feb 10, 2023 9:36:02 GMT 1
Yep %100 digital temp readers the back to can get hot on a 500 and this bloke's not taking the risk
Post by JonW on Feb 10, 2023 12:59:58 GMT 1
Good stuff. Thanks all! Im sure that you all knew that I knew it was a 500 Anyone know the units fitted, they seemed quite a neat solution.
Post by yamman1066 on Feb 10, 2023 14:47:26 GMT 1
ask the seller ??
Post by stirling11 on Feb 11, 2023 16:56:04 GMT 1
From what I’ve been told the back left cylinder is the last to get coolant to it and can seize
Apparently there is a fix for this issue by adding in another coolant circuit that rectifies this issue
So, yes, temp gauges would make sense
