Post by Chewie01 on Feb 10, 2023 18:28:31 GMT 1
RE the new rectifier, it looks right to me. You do want to make sure the rectifier body has a good earth to the chassis. A continuity check with a Digital Volt Meter is what I tend to do if the chassis has been painted/powder coated. Chances are it'll earth through the threads, but best check it. On the recommendation of my bike mechanic mate I fitted an extra connection from the bottom screw of the rectifier to the battery to make sure of a solid connection. It was possibly a bit overboard but at least I won't have issues with bad earths.
Post by ypvsrestore on Feb 11, 2023 8:02:53 GMT 1
With a f2 wiring loom , will this work with N instruments and rotor/engine etc?๐ค
Post by lcmarky on Feb 11, 2023 10:55:20 GMT 1
A continuity check with a Digital Volt Meter is what I tend to do if the chassis has been painted/powder coated. Chances are it'll earth through the threads, but best check it. On the recommendation of my bike mechanic mate I fitted an extra connection from the bottom screw of the rectifier to the battery to make sure of a solid connection. It was possibly a bit overboard but at least I won't have issues with bad earths. Like you say, it may be overkill & you may need the connector height on the -ve battery post in time with an Optimate or something. Belt & Braces isn't a bad approach!
Post by ypvsrestore on Feb 16, 2023 23:06:24 GMT 1
Got the motor in the frame today, first issue The mikuni tmx 30mm cant fit with the cable installed ( frame is in the way) and i dont feel like changing my reeds now. There is alu banshee instake on and boyseen reeds Had a set of 28mm keihin carbs, they fit nicely Might be going that route and keeping them on. If anyone have good advice on /setups with the 30mm tmx please do share Else, iam still waiting for decals for my tank and plastic so i can have it finished Also got my rear caliper fitted with new pistons and a set of Brembo pads. Stay tuned Pictures later, forgot to take some
Post by ypvsrestore on Feb 17, 2023 11:22:18 GMT 1
So.. removed the tmx as i said and fitted a set of 28mm keihin i got from ed toomey US. No issues with clearence๐ Fitted original new chain guard i had and chain and its starting to look like a awsome ride more and more . Going to bleed the rear caliper now and see if i can work something out regarding the sight glass on my front master . Damn glas preventing me from having those awsome tzr calipers working The throttle cable workw smooth but do i just Mount the splitter part with zip tie to the frame or ? Dont seem to be any mounting for it apparently
Post by masonmart on Feb 17, 2023 11:42:31 GMT 1
You are doing devastatingly well and this is from I who know nothing but aren't the barrels and top casing supposed to be coated black?
Post by ypvsrestore on Feb 17, 2023 11:44:44 GMT 1
Yes if your doing original , then they are suppose to be black But not so much the case on this bike .just saving it from the grave it was in and i do like the black head and the rest raw, really pops i think . ๐๐ Plus less to paint๐คท๐
Post by masonmart on Feb 17, 2023 13:04:09 GMT 1
Yes if your doing original , then they are suppose to be black But not so much the case on this bike .just saving it from the grave it was in and i do like the black head and the rest raw, really pops i think . ๐๐ Plus less to paint๐คท๐ For sure but the rest is so good and you know what anoraks are?
Post by ypvsrestore on Feb 17, 2023 14:04:29 GMT 1
Anoraks ?๐คท๐ค
Post by ypvsrestore on Feb 24, 2023 20:41:37 GMT 1
Installed a new sight glass to the front brake master ( ebay cheap crap) but seems to work so thats perfect. Got the front calipers, tzr 250, bleed and it feels nice and strong. Awaiting exhaust gaskets to install pipe and need to pick up rear brake pedal from powder so i can bleed the rear brake as well. Can anyone confirm if these mirrors are original ? And oh Yeah, found a original rd poster and had it proff. Framed ๐ nice
Post by JonW on Feb 25, 2023 0:42:39 GMT 1
Mirrors are not original sadly, they dont have 'YAMAHA' and some DOT E markings on the backs.
Like the framed pic!
FYI you can still get the screw (the lever's plunger adjuster) from Yam, tho maybe yours has been recut to accomodate that socket bolt. worth looking at the thread before buying one if you were bothered.
Post by ypvsrestore on Feb 27, 2023 21:57:13 GMT 1
So, Ive been trying to bleed the rear brake. Nothing ! I dont own a vacuum bleeeer but checked everything, caliper looks goood and seals are fine But no oil gets to the caliper it seems.
Pump i took off the frame and held a finger on the outlet and pumped a few times, there was pressure released.
What an i doing wrong here ?
Double 4 pot up front went fairly smooth, rear master is dead. Hello๐
Post by JonW on Feb 27, 2023 22:46:24 GMT 1
The rears can be a pain, you can wedge the lever down and hope that helps get some air out, also life the caliper above the master and turn it around.
I had the same problem after i rebuilt my F1s rear brake.
A vac bleeder will help, but you can do the same with a syringe and also back bleed.
Post by ypvsrestore on Mar 27, 2023 21:35:30 GMT 1
Still having issues sorting the electrics/wiring loom and which wires goes where..its a mess But hopefully soon so i can finish it up with fluids and have a new MOT ๐ test fit of tank and plastic and its looking pretty sexy
Post by ypvsrestore on Mar 27, 2023 21:36:00 GMT 1
