robw
Post by robw on Jan 8, 2023 14:14:25 GMT 1
Hi, I have (I think) a rd80lc Swinging arm, the pivot area is wider, so the 125 engine isn't a tight fit. I have had it fitted to my 125, but replaced it with a standard one. The bushes and paint are good. £80 + post
Post by museumman on Mar 14, 2023 14:48:21 GMT 1
If you still have it Rob you could try moped forums as this should also fit around Yamaha's 50cc motors (RD80LC was based on the RZ50) I'm thinking for people who do custom mopeds like RZ 50 replicas with spoked wheels and so on.
Otherwise to make it fit a 125, someone can get some steel tube to extend the bush section up to the cases, with a stay-bar welded backwards where there should be the hollow sheeted section.
robw
Post by robw on Mar 14, 2023 20:59:27 GMT 1
Cheers for the info Rob
