bikingbagga
Newbe
Restoring RD400 looking to modify VM carb for oil injection
Post by bikingbagga on Nov 26, 2022 2:10:55 GMT 1
Live in Southern California since 1980 but originally from Maghull, Merseryside. Race a Suzuki RGV250 & a KTM RC390R. Bikes in my collection 74 Suzuki GT750, 76 Yamaha RD400 (restoring) 2003 Honda CR125, 2000 Yamaha YZ250, 1972 Kawasaki H2 (restoring) 1990 KX500 (restoring) 2005 Honda CRF250 Enduro, 1991 Suzuki RGV250, 2016 KTM RC390R Cup Bike In the UK I have a 2012 BMW K1300S I keep at my sisters in Leeds use it when I come over which is fairly regular because I'm now a retired mechanical engineer.
Post by arrdy350 on Nov 26, 2022 8:13:51 GMT 1
Welcome to the Forum and nice collection 😀👍
Post by geoffb on Nov 26, 2022 10:39:06 GMT 1
Welcome! SoCal is such a lovely location for driving/riding 😎
Post by arrow on Nov 26, 2022 10:59:13 GMT 1
Welcome in.
Post by chrisg on Nov 26, 2022 15:40:32 GMT 1
Welcome. Some nice crossers in there, my first passion. I imagine the kx500 is a bit of an animal
Post by dusty350 on Nov 26, 2022 21:08:26 GMT 1
Hi Welcome to the forum Dusty
bikingbagga
Newbe
Post by bikingbagga on Nov 27, 2022 0:55:41 GMT 1
Glad to be here. We have great roads here in Santa Clarita and speed cameras don't exist and very few cops to bother with you. I'm restoring the 76 RD400 as a cafe racer style with aftermarket LED headlight / tail light etc and I have crafted a seat My wiring harness is a bit of a mess. Any good used ones availble? I'm also restoring the oil injection system. I have the carbs with the oil injection spigot but new Mikuni VM carbs would be better. What has everyone done for an upgrade and can the oil injection spigot be added Cheers Rob
Post by dusty350 on Nov 27, 2022 9:41:59 GMT 1
I used Pwk28 Keihins on my 400e. A recognised upgrade for Ac's and Lc's, they can still fit with an airbox - well, certainly on Lc's anyway. Generic jets may need to be tweaked, but that will be the same with any aftermarket carbs you buy. Oil spigots can be fitted, no problem. I bought my carbs from Forum Guru "Muttsnuts", who added the spigots before posting to me. I then decided to fit billet inlets, and to save removing oil lines from the carbs everytime the carbs need to come off, Mutts fitted spigots to the inlets too, so I blanked off the carb fittings and the oil pipes went straight into the inlets; 20210403_160949 by dusty miller, on Flickr 20210905_103733 by dusty miller, on Flickr Those carbs are good for mid 70's bhp. I have seen oil spigots fitted to standard rubber reed blocks, but never done it so cant vouch for that. Dusty
bikingbagga
Newbe
Post by bikingbagga on Nov 28, 2022 1:31:08 GMT 1
Thank you for the info that helps. I like the idea of creating the manifold looks very clean. Because I like to engineer stuff I'm thinking about grafting on a Suzuki GT750 starter / gearing to a RD engine. Anybody ever tried to create a electric start RD?
Post by dusty350 on Nov 28, 2022 8:46:06 GMT 1
Yea, Yamaha did with the Rd200 !!
bikingbagga
Newbe
Post by bikingbagga on Nov 29, 2022 1:21:57 GMT 1
Yes they did I forgot about that. If the RD200 rotor has the same taper as the RD400 then its likely feasible that you could adapt the Rotor / Magneto / Starter from the RD200
Post by dusty350 on Nov 29, 2022 8:41:29 GMT 1
The Yam parts may be closer to start with. My question is why though ? Will add weight, and part of the Cafe build thinking is to reduce it - especially on an Ac which are pretty industrial to start with. Lc's were waay lighter due to a lot of parts being made from plastic, which ultimately contributed to a better power to weight ratio. You can get some trick, smaller kickstarts that look good, and a well set up Ac should start first or second kick usually. I would add a modern digital ignition if yours is a points model - there is something like a 2 kilo difference between a standard Cdi rotor and a Powerdynamo rotor - not sure what the points set up weighs but i doubt it will be as light as the Powerdyno, or offer the same performance as a modern ignition. Kickstart wise, I have a 3ma on my Cafe bike, and it's really neat; 20210608_092712 by dusty miller, on Flickr Dusty
Post by tony2stroke on Nov 29, 2022 11:21:31 GMT 1
The rotor off the RD200 is a massive heavy beast, it is a dual purpose item, its a dynamo, charges electric system when bike running and starts the engine when power reversed to the system, 25mm crank bearing inner for left side rd200, 25mm crank bearing inner for left rd400 bearing, so technically the crank should accept the rotor, the whole electrical system for the rd200 is different due to the dynamo, you would have to change the whole system, I don't think its a good idea, but its up to you, your bike your way
Post by bruceybonus on Dec 2, 2022 22:37:59 GMT 1
Welcome. That is a great selection of bikes you have there!
