Post by donkeychomp on Nov 7, 2022 23:36:40 GMT 1
To mount an LC seat without the latches? I spent a while staring up at the seat and can't clearly see a solution, though that might be down to some Jammy Red Roo.
Post by JonW on Nov 8, 2022 0:10:20 GMT 1
Im going to say 'no'... not without some other kind of fixings being created at the back. It will sit 'on' the bike, but it wont stay put once you get going, and it wont be fully fitted in place for the lines/panel gaps without clicking into place etc
You could use the seat's latch mounts (the bolt stubs) and make up some L brackets (ala older bikes like the XT500) and then use something around the frame for you to put a bolt through.
I will say tho, that the older bolt on seats are a pain, I do so love the fact you can unlatch the ones on the LC/YPVS.
Post by donkeychomp on Nov 8, 2022 0:19:33 GMT 1
Thanks Jon. Looks like I need latches.
Post by JonW on Nov 8, 2022 0:59:02 GMT 1
FWIW the LC and YPVS share the same latch other than the length of the lever... and, I reckon other Yama of the era do too. Ive been looking at latches the past week, can you tell lol.
Post by LC_BOTT on Nov 8, 2022 8:27:45 GMT 1
V max latches were cheap last time I was looking, and just 'pull' to release, but they don't have a lock fitted to either side.
Post by midlifecrisisrd on Nov 8, 2022 9:53:48 GMT 1
Pair of V max latches on eBay for £5 + £15 post from US and £5 duty
Post by abar121 on Nov 8, 2022 12:50:42 GMT 1
I've used some XJ600 latches in the past. The early model, not the Divy.
Post by headcoats on Nov 8, 2022 13:19:32 GMT 1
My buell has a wing nut to hold the seat on and my Triumph uses 2 M6 bolts to hold it so the LC seat catches are like Rolls Royce in comparison !
Post by abar121 on Nov 8, 2022 14:14:15 GMT 1
My buell has a wing nut to hold the seat on and my Triumph uses 2 M6 bolts to hold it so the LC seat catches are like Rolls Royce in comparison ! Yep, my Sprint 1050 had a couple of bolts holding on the back of the seat. A total pain to get back in.
