cox
Post by cox on Oct 28, 2022 6:25:44 GMT 1
Hi i just got a 1982 rd250lc matching numbers does any one know what the numbers on the exhaust should be please
Post by oldelsieboy on Oct 28, 2022 7:00:09 GMT 1
Hi i just got a 1982 rd250lc matching numbers does any one know what the numbers on the exhaust should be please 4L0-14711 4L0-14712 OEB
Post by shaunthe2nd on Oct 28, 2022 8:59:19 GMT 1
As above, but there is a BUT. The 250's and 350's are stamped the same but are different! Have a look at Xaviers web page as follows: www.rd350lc.net/pageEXHAUST.htmthis explains the differences.
cox
rd250lc
Oct 28, 2022 12:42:13 GMT 1
Post by cox on Oct 28, 2022 12:42:13 GMT 1
Hi i just got a 1982 rd250lc matching numbers does any one know what the numbers on the exhaust should be please 4L0-14711 4L0-14712 OEB thanks mine have 4L2-14721 ON THEM
Post by shaunthe2nd on Oct 28, 2022 13:02:02 GMT 1
German restricted pipes then. Check your carb refs too, if they also marked 4L2 then they are restricted too.
rd250lc
Oct 28, 2022 13:35:58 GMT 1
Post by lcmarky on Oct 28, 2022 13:35:58 GMT 1
German restricted pipes then. Check your carb refs too, if they also marked 4L2 then they are restricted too. Welcome along and here is a fantastic opportunity for a set of new pipes & carbs!!
cox
rd250lc
Oct 28, 2022 14:25:40 GMT 1
Post by cox on Oct 28, 2022 14:25:40 GMT 1
Thanks what pipes is that for please just took it out for a few miles is it normal for the oil light to flicker on when you slow down
rd250lc
Oct 28, 2022 15:12:49 GMT 1
Post by fletche36 on Oct 28, 2022 15:12:49 GMT 1
Thanks what pipes is that for please just took it out for a few miles is it normal for the oil light to flicker on when you slow down if your oil light is flickering when you brake i would put some more 2t in the oil tank .
rd250lc
Oct 28, 2022 17:18:11 GMT 1
Post by tony2stroke on Oct 28, 2022 17:18:11 GMT 1
You can take the restricting bits out the exhausts if you cut and weld them back up, 4L2 carbs would just want 4L1 spec jetting to bring them to un-restricted spec, not a big deal.
And yes put some oil in the oil tank.
cox
rd250lc
Oct 29, 2022 14:01:05 GMT 1
Post by cox on Oct 29, 2022 14:01:05 GMT 1
German restricted pipes then. Check your carb refs too, if they also marked 4L2 then they are restricted too. Hi mate no on the carbs it has 4l1 there ok then are they
rd250lc
Oct 29, 2022 14:25:37 GMT 1
via mobile
Post by shaunthe2nd on Oct 29, 2022 14:25:37 GMT 1
Yes should be provided fitted with correct internals, so most likely if someone went to the trouble of switching the carbs.
