Post by donkeychomp on Oct 24, 2022 21:59:10 GMT 1
Good idea or not? They are only a fiver more than stock ones.
Post by billbott on Oct 24, 2022 22:16:51 GMT 1
I had them on my 350 before I fitted the vape system after my stator failed, they worked well and it seemed easier to start. I’ve just put the same set on my 250 project
Post by donkeychomp on Oct 24, 2022 22:38:36 GMT 1
Cheers for the info. Another Norbo order beckons...
Post by JonW on Oct 25, 2022 0:21:18 GMT 1
Its a Pros n Cons thing I reckon. Ie they are new not 30+yrs old, they are cheap chinese not Japanese etc etc.
Ive used Dynateks in the past and theyve been great, but not cheap like these coils.
I reckon you can do the job even cheaper if you work out what coil they actually are part no wise and then shop on that and make your own bracket / wiring etc.
Post by abar121 on Oct 26, 2022 10:53:33 GMT 1
The pitbike coils are dirt cheap and work well after you replace the caps.
Make sure you use decent terminals when wiring them up. No point in doing all of this and then having a duff connection.
Post by donkeychomp on Oct 26, 2022 21:07:56 GMT 1
Thanks lads. All good info!
