Post by kosaprasa on Oct 19, 2022 19:46:04 GMT 1
i never work with LC 4L0/4L1 models. Goes top end ( cylinders, head, carbs... ) on bottom of 4L0/4L1? thanks for anserws
Post by midlifecrisisrd on Oct 19, 2022 20:11:53 GMT 1
Like the 29l and 31k the 4l1 and 4l0 bottom ends are the same
Post by shaunthe2nd on Oct 19, 2022 20:33:16 GMT 1
Oil pump and oil pump worm shaft need changing too to suit at same time.
Post by jon on Oct 19, 2022 20:37:01 GMT 1
Oil pump and oil pump worm shaft need changing too to suit at same time. Isn’t a 350 YPVS worm and shaft the same as a 350 LC? Surely it’s a 250/350 difference rather than a YPVS/LC difference? Jon
Post by shaunthe2nd on Oct 19, 2022 20:53:16 GMT 1
Oil pump and oil pump worm shaft need changing too to suit at same time. Isn’t a 350 YPVS worm and shaft the same as a 350 LC? Surely it’s a 250/350 difference rather than a YPVS/LC difference? Jon Correct. But the question was about 4L1/4L0 interchangeability, so when switching 4L1 (250) with 4L0(350) top ends or vice versa you need to to also fit the correct pump and worm.
Post by midlifecrisisrd on Oct 19, 2022 20:55:05 GMT 1
Oil pump and oil pump worm shaft need changing too to suit at same time. Isn’t a 350 YPVS worm and shaft the same as a 350 LC? Surely it’s a 250/350 difference rather than a YPVS/LC difference? Jon Correct Jon Hence why I said like the 29l and 31k Same other than oil pump, drive, clutch basket o ring and front sprocket 😬 Steve
Post by jon on Oct 19, 2022 21:34:04 GMT 1
Isn’t a 350 YPVS worm and shaft the same as a 350 LC? Surely it’s a 250/350 difference rather than a YPVS/LC difference? Jon Correct. But the question was about 4L1/4L0 interchangeability, so when switching 4L1 (250) with 4L0(350) top ends or vice versa you need to to also fit the correct pump and worm. Just picking up on the cc difference rather than the model difference. Jon
Post by 4l04ever on Oct 19, 2022 21:37:48 GMT 1
I think 29L has different reed gaskets to 31K... I think they may be the same as 4L1/4L0.
Post by JonW on Oct 19, 2022 23:00:26 GMT 1
I think 29L has different reed gaskets to 31K... I think they may be the same as 4L1/4L0. yes-ish, its said the ypvs 250 reeds are better than the 4L0 and used by racers in 4L0s etc. Bear in mind that the 250 also has different PVs as well... same castle seals, but different O rings and holders. Different manifolds too. ... As per the Dejan's original question, yes swapping to the 350 version is the same idea as for the later models.
Post by kosaprasa on Oct 20, 2022 14:59:15 GMT 1
Post by midlifecrisisrd on Oct 20, 2022 15:26:55 GMT 1
Easy answer then
No they don't
Post by midlifecrisisrd on Oct 20, 2022 15:28:03 GMT 1
Looks like auto correct has changed ypvs to goes in your original post hence the confusion
Post by jon on Oct 20, 2022 18:19:21 GMT 1
Post by JonW on Oct 20, 2022 22:52:35 GMT 1
That's a 'firm no', as has been said.
