Post by linx on Oct 6, 2022 20:13:03 GMT 1
This doesn't look right to me. Left carb missing a brass ball and a little brass pipe compared to the other. Can someone confirm if that is standard or not?
Post by muttsnuts on Oct 6, 2022 20:32:00 GMT 1
standard, brass pipe is the choke side carb, that pipe goes into the float bowl jet hole for the choke (LHS carb), the RHS carb doesn't have it or need it as the choke circuit is made between the 2 carbs by the rubber pipe going between them
HTH
Post by linx on Oct 7, 2022 8:54:38 GMT 1
standard, brass pipe is the choke side carb, that pipe goes into the float bowl jet hole for the choke (LHS carb), the RHS carb doesn't have it or need it as the choke circuit is made between the 2 carbs by the rubber pipe going between them HTH Thanks for that Mutts. What about the hole next to the missing pipe? Should there be a brass ball in it on the carb without the choke?
