Post by headcoats on Sept 26, 2022 18:10:33 GMT 1
Is there any decent satin black brush on paint just to touch up the chips ?
Post by midlifecrisisrd on Sept 26, 2022 19:02:35 GMT 1
Mrs giving you a hard time for being too rough doing the vacuuming 🤔
Post by headcoats on Sept 26, 2022 20:47:58 GMT 1
LOL It's the Bonneville oil cooler,I put masking tape on to touch something else up and as I pulled the tape off the paint came off ffs Sure I used Humbrol model enamel paint in a past life
Post by donkeychomp on Sept 26, 2022 22:21:35 GMT 1
Yep, use that. I have.
Post by steve h on Sept 26, 2022 22:27:57 GMT 1
Is there any decent satin black brush on paint just to touch up the chips ? I'd find a better fish and chip shop if I were you. I've pissed on my chips quite a few times but never touched them up.... I once bought hammerite satin black to paint wheels....It was carp. too "watery"
Post by headcoats on Sept 26, 2022 22:47:07 GMT 1
A new oil cooler is only £462 from Fowlers Makes LC stuff look cheap !
Post by stusco on Sept 27, 2022 8:32:26 GMT 1
Satin black touch up paint stick
Post by steve63 on Sept 27, 2022 10:03:28 GMT 1
Is there any decent satin black brush on paint just to touch up the chips ? If you only have aerosol I just spray a bit of the paint into the lid then use a brush to apply it.
Post by chrisg on Sept 27, 2022 11:00:47 GMT 1
Is there any decent satin black brush on paint just to touch up the chips ? If you only have aerosol I just spray a bit of the paint into the lid then use a brush to apply it. Same. I used to pinch my daughters little paint brushes.😯
Post by steve63 on Sept 27, 2022 16:00:04 GMT 1
If you only have aerosol I just spray a bit of the paint into the lid then use a brush to apply it. Same. I used to pinch my daughters little paint brushes.😯 You evil man. Unless that is you cleaned them and put them back I used to do the Airfix models so I still have some paint and brushes. Some of the paint must be nearly 50 years old, I kid you not, but two minutes using a bit of bent welding rod in a battery drill they are as good as new again.
Post by tony2stroke on Sept 27, 2022 17:48:31 GMT 1
Post by bruceybonus on Dec 2, 2022 23:11:15 GMT 1
I can recommend Halfords Satin Black Engine enamel.
I've used it on lots of engines, frames, rads etc. Easy to go on and lasts well.
GOOD TIP: Use a sponge brush with a dabbing technique to give a non-brushed look finnish.
