Oil leak
Sept 18, 2022 11:45:27 GMT 1
via mobile
Post by veg on Sept 18, 2022 11:45:27 GMT 1
Before I start removing stuff. Just gone to move the hybrid it’s only done minimal miles and hasn’t been started for at least 6 months. So totally rebuilt everything. As I’ve moved it loads of two stroke oil has poured out from the belly pan. I obviously need to remove the belly pan and have a butchers . Simple question any ideas as to where and why? Quick glance oil lines externally all seem in tact no splits etc, but stumped without removing cases etc. any ideas
Oil leak
Sept 18, 2022 11:55:04 GMT 1
via mobile
Post by veg on Sept 18, 2022 11:55:04 GMT 1
I’ve had wet sumping before on old British bikes where the oil has bypassed a worn oil pump, this is a newly rebuilt pump in a rebuilt engine
Post by stusco on Sept 18, 2022 11:59:07 GMT 1
It’s usually coming from the reed blocks through the hole in between the barrels and dripping off the studs underneath
Oil leak
Sept 18, 2022 12:05:21 GMT 1
via mobile
veg likes this
Post by midlifecrisisrd on Sept 18, 2022 12:05:21 GMT 1
2 options
First one as above. Non return valves at pump slowly pass oil and it seeps through the reed gaskets
Other one I had was the fibre washer on a newly built pump compresses and leaks oil at the bleed screw. Just needs nipped up. My bike did this
Oil leak
Sept 18, 2022 12:09:05 GMT 1
via mobile
Post by veg on Sept 18, 2022 12:09:05 GMT 1
Thanks lads I’ll have a look shortly shitty thing I was bringing it into the house to sit in my office for the winter, with a new carpet not sure the wife will be happy.
