paulf
rd370lc
Aug 28, 2022 14:39:24 GMT 1
Post by paulf on Aug 28, 2022 14:39:24 GMT 1
Took the bike out for a steady ride today. . bike fully built and has around 2000 miles on it. All set up on the dyno and never had any issues always starts straight away. new coils etc. Anyway ran fine just approaching near to home and in 3rd gear it just cuts out There wasn't much fuel in the tank. could get it going. got it back home cleaned the carbs, topped up with fuel , checked the plugs still wont start. please help, thoughts. i wasnt ragging it and temp guage below half.
i cannot think its seized as moves freely.
rd370lc
Aug 28, 2022 15:18:06 GMT 1
via mobile
Post by beardy on Aug 28, 2022 15:18:06 GMT 1
Guessing you still have a spark? I know you said you checked the plugs.
rd370lc
Aug 28, 2022 15:40:10 GMT 1
Post by rigga on Aug 28, 2022 15:40:10 GMT 1
Spark Fuel Compression
Which is missing ?
paulf
rd370lc
Aug 28, 2022 15:51:02 GMT 1
Post by paulf on Aug 28, 2022 15:51:02 GMT 1
Just checked no spark.
rd370lc
Aug 28, 2022 15:58:48 GMT 1
via mobile
Post by Tobyjugs on Aug 28, 2022 15:58:48 GMT 1
I think I would go straight to the Kill switch circuit and check that through.
paulf
rd370lc
Aug 28, 2022 16:32:48 GMT 1
Post by paulf on Aug 28, 2022 16:32:48 GMT 1
fuel coming through lots of compression.
It felt like it had run out of fuel. more fuel in. cleaned carbs out. Always started straight away. I am pulling my hair out, what's left of it.
rd370lc
Aug 29, 2022 21:55:23 GMT 1
via mobile
Post by dave1963 on Aug 29, 2022 21:55:23 GMT 1
What ignition are you running if its a zeel check your rev limit setting had mine kept setting its self to zero because of interferance from ignition system you need to run restor plugs and caps to stop it took me ages to find it ended sending zeel back to get tested and they found it
rd370lc
Sept 26, 2022 7:21:46 GMT 1
via mobile
Post by Shytalk on Sept 26, 2022 7:21:46 GMT 1
Worth checking that the rotor is in place and not slipped, woodruff keys sometimes shear.
rd370lc
Sept 26, 2022 8:41:06 GMT 1
Post by shaunthe2nd on Sept 26, 2022 8:41:06 GMT 1
Check fuse box for blown fuses or more likely lose/dirty connections.
