Post by stusco on Aug 24, 2022 15:58:52 GMT 1
Is this sealant ok for sealing the waterways on a ‘o’ringed 350 ypvs head
Post by midlifecrisisrd on Aug 24, 2022 17:49:46 GMT 1
Should be fine
It was clear pro seal stuff I used
Post by stusco on Aug 24, 2022 17:56:45 GMT 1
I might have clear as well 👍
Post by jon on Aug 24, 2022 18:13:09 GMT 1
Interesting question.
I was thinking of using copper gasket spray on mine?
Post by muttsnuts on Aug 24, 2022 18:56:41 GMT 1
RTV is the correct stuff, works a treat - colour wise, don't think the head or barrels will care too much !!
Post by jon on Aug 24, 2022 19:03:44 GMT 1
RTV is the correct stuff, works a treat - colour wise, don't think the head or barrels will care too much !! I which case (sic) can’t you just use the threebond you did on the case halves? Jon
Post by midlifecrisisrd on Aug 24, 2022 19:48:51 GMT 1
RTV is a lot easier to clean off when required
Whiff of petrol and it's gone
Post by midlifecrisisrd on Aug 24, 2022 19:53:40 GMT 1
RTV is the correct stuff, works a treat - colour wise, don't think the head or barrels will care too much !! You have to treat it like an advert on the telly One side not coloured, one side coulored One base gasket has to be non British, the other rainbow coloured One gasket on the engine has to identify as not being a gasket Steve 😁
Post by Tobyjugs on Aug 24, 2022 21:02:46 GMT 1
RTV is the correct stuff, works a treat - colour wise, don't think the head or barrels will care too much !! That made me laugh 🤣😂
Post by 4l04ever on Aug 24, 2022 23:35:09 GMT 1
RTV is the correct stuff, works a treat - colour wise, don't think the head or barrels will care too much !! I heard once you go black.....
crono
Post by crono on Aug 26, 2022 9:41:10 GMT 1
I never use sealants on O-ring heads. No need to if the surfaces are clean and not damaged. On normal head I also never use liquid sealants, just a new gasket.
Post by stusco on Aug 26, 2022 12:48:51 GMT 1
I never use sealants on O-ring heads. No need to if the surfaces are clean and not damaged. On normal head I also never use liquid sealants, just a new gasket. It only has 1 ‘o’ ring so needs sealant for the waterways
Post by Tobyjugs on Aug 26, 2022 14:51:37 GMT 1
On a 4L0 engine I would also use some sealant around the stud holes to try and keep the cooling water from entering that space. On my YPVS cylinder head with an inner and outer O-ring I just use O-ring lubricant.
Post by stusco on Aug 26, 2022 15:02:58 GMT 1
Head fitted yesterday i had already checked the squish 1.2mm ,filled with coolant today fired second kick so good to go 😀 Great work on the head by muttsnuts
