Post by jon on Aug 9, 2022 18:47:13 GMT 1
I have a vague recollection of my OEM mirrors vibrating a little on my first F2 I have around 1989.
My latest one has patern mirrors and they vibrate a lot at a certain number of revs.
Is this normal for both, or just pattern?
Post by mannanan on Aug 9, 2022 20:24:31 GMT 1
Sorry if this appears contrary Jon, but I have an 89 F2 with original mirrors and I have to say they are rock solid. Never vibrate, give a good clear view of everything behind and I could not fault them.
Post by Chewie01 on Aug 9, 2022 21:33:42 GMT 1
I have an 86 F2 with pattern mirrors and I have a clear view of my sholders and arms.
Post by jon on Aug 9, 2022 22:01:35 GMT 1
OK thanks for the replies so far.
From memory it’s the left that’s the problem, but only at certain RPM. Tends to be low down.
Not a major problem by any means, just keen to have others input.
When bought it had original scratched mirrors and did the same. It’s not the crank as I had it redone and still no difference. Also as said one mirror is worse than the other so not crank vibrations.
Post by JonW on Aug 9, 2022 22:19:02 GMT 1
could be a crack in the birdcage?
Ive read before that the pattern mirrors vibrate, but interesting your OEMs did it too.
Post by davecroucher57v on Aug 9, 2022 22:39:48 GMT 1
my f1 is ok. touching fairing.
Post by evochris on Aug 10, 2022 11:29:28 GMT 1
Mine vibrate at certain revs on the F2, about 3k IIRC but mostly as you rev it at a standstill. They are original Yamaha items. I have not had a crank rebuild, or any engine work from new except reeds, clutch and a carb clean so I don't know the health of my crank. (will be finding out soon I am sure as 19k miles on the clock in 34 years).
