Post by jon on Aug 4, 2022 18:58:29 GMT 1
Hi all,
Does anyone know the genuine part numbers, but more importantly how many of each type are needed for the sidecase screws both side on a YPVS.
It isn’t clear from the fishe.
I could probably work it out at the weekend, but wondered if anyone had this data already?
TIA
Post by midlifecrisisrd on Aug 4, 2022 19:41:34 GMT 1
From memory clutch case 8 x 30mm 92501-06030 and 1 x 40mm 92506-06040
Sprocket cover 3 x 55mm 92506-06055 and 4 x 20mm 92506-06020
Oil pump 3 x 20mm 92506-06020
Those are the original numbers, not the superseded
Post by midlifecrisisrd on Aug 4, 2022 19:44:06 GMT 1
New numbers
9851706020 x 7
9788506030 x 8
9850706040 x 1
9850706055 x3
Post by jon on Aug 4, 2022 21:25:48 GMT 1
Spot on Steve,
I’ll order them up.
Post by chrisg on Aug 5, 2022 7:19:13 GMT 1
I think all the new fixings are black and not the original olive green the Yamaha sell.
Post by jon on Aug 5, 2022 7:32:00 GMT 1
I think all the new fixings are black and not the original olive green the Yamaha sell. Correct. But I know a man that can 😉 Jon
Post by jon on Aug 5, 2022 7:35:25 GMT 1
They’ve also got a wired what looks like a recess half way down the thread by the looks of them?
Post by stirling11 on Aug 6, 2022 15:09:47 GMT 1
Perhaps the recess, if unthreaded, is to stop the screw chafing the covers, particularly on the left side as it's plastic
Post by midlifecrisisrd on Aug 6, 2022 17:13:00 GMT 1
I'm just ponderi g whether to buy a bulk batch of JIS and cap head bolts, get them plated olive and make up engine sets for LC and ypvs 🤔
Post by jon on Aug 6, 2022 17:52:15 GMT 1
I'm just ponderi g whether to buy a bulk batch of JIS and cap head bolts, get them plated olive and make up engine sets for LC and ypvs 🤔 Steve Do they come with the little dimple in though? Anyone wanting the correct JIS olive screws would want the dimple too. Jon
Post by midlifecrisisrd on Aug 6, 2022 18:29:02 GMT 1
I'm just ponderi g whether to buy a bulk batch of JIS and cap head bolts, get them plated olive and make up engine sets for LC and ypvs 🤔 Steve Do they come with the little dimple in though? Anyone wanting the correct JIS olive screws would want the dimple too. Jon No dimple from memory, you got a pic? Did a load a few years ago and nobody mentioned anything, I'll need to check the ones I have No point throwing money away for nothing as have to buy around 1000 screws to make it viable Here's a pic from the supplier Steve
Post by jon on Aug 6, 2022 18:48:44 GMT 1
Post by midlifecrisisrd on Aug 6, 2022 19:01:51 GMT 1
🤔 I'll have to check some genuine screws
I wonder if the new genuine ones have the dimple, I'll have to check what I've got as probably got some original genuine ones but can't remember a dimple but hey I've got Magoo eyes 😆
Yes a hammer And centre punch but don't know if I fancy doing 1000 of them
Post by LC_BOTT on Aug 6, 2022 20:06:00 GMT 1
I thought the dimple is what signifies them as JIS screws, rather than plain old Philips screws?
Post by pigboy on Aug 7, 2022 6:36:14 GMT 1
What size are the screws ? I need to helicoil a few or should I use something else
Post by jon on Aug 7, 2022 8:06:31 GMT 1
What size are the screws ? I need to helicoil a few or should I use something else They are M6 x 1.0. Make sure you use a 2D+. Helicoil is a brand, all coil inserts will work well IF fitted correctly. Jon
Post by jon on Aug 7, 2022 8:07:40 GMT 1
I thought the dimple is what signifies them as JIS screws, rather than plain old Philips screws? That was my understanding to. Jon
Post by reedx on Aug 7, 2022 10:46:19 GMT 1
From memory clutch case 8 x 30mm 92501- 06030 and 1 x 40mm 92506- 06040Sprocket cover 3 x 55mm 92506- 06055 and 4 x 20mm 92506- 06020Oil pump 3 x 20mm 92506- 06020Those are the original numbers, not the superseded Steve Just realised the part numbers actually give the thread size and length within the number. If only all manufacturers did this! Colin
Post by midlifecrisisrd on Aug 7, 2022 11:25:11 GMT 1
From memory clutch case 8 x 30mm 92501- 06030 and 1 x 40mm 92506- 06040Sprocket cover 3 x 55mm 92506- 06055 and 4 x 20mm 92506- 06020Oil pump 3 x 20mm 92506- 06020Those are the original numbers, not the superseded Steve Just realised the part numbers actually give the thread size and length within the number. If only all manufacturers did this! Colin Yes, makes it easy to work out replacements First part of number is the type of screw/colour. There are some exceptions with particular nuts and bolts but generally the info is in the number Steve
Post by freddie19 on Aug 9, 2022 2:25:21 GMT 1
Guys, original YPVS genuine olive green engine case cover screws don't have the dimple.👍
Post by abar121 on Aug 9, 2022 9:39:02 GMT 1
I quite like black allen bolts personally.
